SupraTRD83 Posted March 5, 2009 Share Posted March 5, 2009 when checking/changing fuses would you advise removing the battery connection? tried doing something with the lighter earlier and a nice fuse later my lighter/blowers/clock dont work Quote Link to comment Share on other sites More sharing options...
georigg Posted March 5, 2009 Share Posted March 5, 2009 No need to remove battery connection when checking fuses. Sounds like when you were looking at/working on cigarette lighter you probably didnt notice grounding one of the +ve wires which would blow the fuse. Just need to be a little careful when working on the car! For info, the cigarette lighter is NOT powered with the ignition off........did you have the ignition on when working at near it???? Rgds George Quote Link to comment Share on other sites More sharing options...
SupraTRD83 Posted March 6, 2009 Author Share Posted March 6, 2009 No need to remove battery connection when checking fuses. Sounds like when you were looking at/working on cigarette lighter you probably didnt notice grounding one of the +ve wires which would blow the fuse. Just need to be a little careful when working on the car! For info, the cigarette lighter is NOT powered with the ignition off........did you have the ignition on when working at near it???? Rgds George yeah like an idiot, wired it up with ignition off then turned igniton on and clock went off so did heaters and cig lighter didnt work no more new id forgot to ground it argh!! Quote Link to comment Share on other sites More sharing options...
