adi2009 Posted March 5, 2009 Share Posted March 5, 2009 I just received my brand new shortblock and head from the US. However, I noticed that the head has metal pieces that look like they should have been machined out. Here are some pictures, what should I do? Quote Link to comment Share on other sites More sharing options...
Missile Posted March 5, 2009 Share Posted March 5, 2009 Sure does look like they are ment to be smooth. Quote Link to comment Share on other sites More sharing options...
Matt H Posted March 5, 2009 Share Posted March 5, 2009 Definately doesnt look right but does it matter? I don't know. Quote Link to comment Share on other sites More sharing options...
jk136 Posted March 5, 2009 Share Posted March 5, 2009 Thats just 'flash' from the casting process. - Its very thin material from where 2 halves of the mould havent quite been together. Should be easy enough to grind off with a Dremel. Just make sure you give it a damn good blow out with an airline afterward (or something to that effect) Quote Link to comment Share on other sites More sharing options...
adi2009 Posted March 7, 2009 Author Share Posted March 7, 2009 Anyone else with some more opinions? Mr Wilson??? Quote Link to comment Share on other sites More sharing options...
TLicense Posted March 7, 2009 Share Posted March 7, 2009 (edited) If it's so thin that you can pick it off with your finger then I would look at removing it, however looking at the pic, it looks reasonably thick, in which case I would leave it be. It's not in an area with anything moving, so having it there isn't going to cause any major headaches. I doubt if you took it back to Toyota and asked to replace it because of the flash, that they would actually take it back. Edited March 8, 2009 by TLicense (see edit history) Quote Link to comment Share on other sites More sharing options...
blackdrift Posted March 8, 2009 Share Posted March 8, 2009 isnt gunna do any damage but it isnt supposed to be there, like jk136 said just left over from the casting. i would grind it off flush carefully and remove any crap if it were me Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 8, 2009 Share Posted March 8, 2009 Looks like you could just remove it with a small file Adi, just give it a blow off, or even run it through a degreesing bath to make sure. Quote Link to comment Share on other sites More sharing options...
adi2009 Posted March 9, 2009 Author Share Posted March 9, 2009 Thanks guys, there also seems to be some burr in the combustion chamber area. Should I carefully use a grinder in this area too??? Quote Link to comment Share on other sites More sharing options...
Missile Posted March 9, 2009 Share Posted March 9, 2009 You would have to be very carfull. If you went a bit to far on those areas the gasket might not seal so well. Thats my guess anyway. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 9, 2009 Share Posted March 9, 2009 I'd clean any burrs and other bits off before fitting mate, if you caught any of that flashing with a socket while fitting/torquing the head and it dislodged it could find its way into an oilway and ruin your day for starters. Is a dremel a die-grinder? If so then thats what you should use, very carefully, with the tidiest stone you can find Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted March 9, 2009 Share Posted March 9, 2009 use a de burer..(and blow off) but this should have been done prior to dispatch.. when i used to work at IRD making rolls royce and pratt and whitney engines,,..(this was always done by us) Quote Link to comment Share on other sites More sharing options...
Kranz Posted March 9, 2009 Share Posted March 9, 2009 As its a new head and block you'll need to run them through a cleaning bath/scrubber and blow all holes/oil ways through anyway, as often they are delivered with casting sand, inclusions, crap in the galleries etc. You don't want a tiny spec of sand ruining your engine Take it to a reputable engine shop and have them de-burr all surfaces, bottom out all tapped holes with a chaser thread and clean the block & head in a hot tank then blow it through and shrink wrap it or whatever. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 9, 2009 Share Posted March 9, 2009 Complain bitterly to Mr Toyota, because that's exactly how they come from the factory. I'd leave it alone, there's sod all to gain from de burring it, and you may get swarf in oilways. I take it the head has been assembled at some time? Quote Link to comment Share on other sites More sharing options...
