mikeyb10supra Posted March 4, 2009 Share Posted March 4, 2009 (edited) Right, now I am really confused.....on the back of this thread here http://www.mkivsupra.net/vbb/showthread.php?t=177714 I sourced a new fuel pump ecu and installed it on the car, went out, fitted it and it fired up perfect with no issues. I have just been out in the car with new ECU fitted and was driving off boost perfectly whilst the engine got up to temprature, sitting at the lights and give it a bit more gas to get away quickly and all of a sudden, jolt, jolt, jolt, jolt, warning lights on and car stalls, lost all power steering and luckily reacted quick enough to catch the steering and pull safetly over. tried firing up the car again and now this new ECU is acting the same as the old one ie starting ok then stalling so I take it this new one is now fluffed as well luckily I had a the loop of wire I used to bypass the ecu, so I could get home, but I am still none the wiser as to why these ECUs keep failing. It also seems to have died on me when I gave it the beans and it has attempted to switch over from 9v to 12v operation Is it really that bad to run the damn thing with a constant 12v as its very quickly starting to get on my nerves Edited March 4, 2009 by mikeyb10supra (see edit history) Link to comment Share on other sites More sharing options...
mikeyb10supra Posted March 5, 2009 Author Share Posted March 5, 2009 Anyone have any ideas on this I had a thought this morning that it may be something to do with the 12v operating mode on the ECU. Is there anything further down the line towards the main ECU/fuses that would effect this as thats my next port of call? Link to comment Share on other sites More sharing options...
charleshmlee Posted October 13, 2010 Share Posted October 13, 2010 Hi there, My car seems to have the same prob as you did, can i know what was the fix at last? Thanks Link to comment Share on other sites More sharing options...
