RHS Oil/ABS panel lights
georigg
I've had a search for this but have not found any info, perhaps someone on the board may have a solution.
The printed circuit board where the oil warning, oil level, ABS indicators are located appears to be a constant source of problems through not lighting when the ignition is switched on.
From my own, it appears that there is an intermittant fault in the PCB tracking that results in an open circuit at times.
Has anyone found a cure for this and what recommendations are there to fix this?
Much obliged for any info.
Rgds
George
