GRIM Posted March 1, 2009 Share Posted March 1, 2009 Hi guys so it's second time this happens to me my car just doesnt accelerate as good as usual up to 3000-3500rpm's but after it, it seems to be ok and acceleration is also normal turbos are OK and boost from about 1800-2000 my car is kinda stock it has TRD ver. S catback TRD filter in oem airbox both cats are in place MINE'S ECU what should i look at? i thought it could be fuel, but it feels ok from 3500rpm so it's not gas i think what about reseting ecu? I haven't changed plugs yet, should i look there? or maybe cats? or injectors? (mileage is ~30K miles) help meeeee also I'm going to remove both cats and make restrictor ring as my car is OBD II (1997, NOT VVTI) i think that check light will turn on am i right? or MINE'S ECU helps? also if check light turns on will the ECU go into fail mode? Quote Link to comment Share on other sites More sharing options...
GRIM Posted March 2, 2009 Author Share Posted March 2, 2009 anyone? Quote Link to comment Share on other sites More sharing options...
supradriver Posted March 2, 2009 Share Posted March 2, 2009 found that hard to read ...may be some other words like 'a' or 'the' might help. Quote Link to comment Share on other sites More sharing options...
supradriver Posted March 2, 2009 Share Posted March 2, 2009 just try an ECU reset, see what that does. some one will come along and know more. Quote Link to comment Share on other sites More sharing options...
