no radio or indicators
hp006
Earlier today i posted that my radio does not work, after a day still no power. Took the car for the drive and now have no indicators. The hazard lights work but the indicators dont. Checked all fuses and all are correct.
Anyone got any ideas as to how i can power the radio and get the indicators working again. Alll worked until i started playing with this stupid radio.
Any help gratefully received.
I think we will need more information from you on this for anyone to try to help you out. Have you modified the wiring in any way? Could you have damaged the wiring when pushing the radio into the panel? Have you accidentally dislodged any of the connectors? If you have modified the wiring then I would suggest putting it back the way it was, if the indicators work then we need to find a way to get your radio working.
Check the connector that plugs into the back of the hazard switch, it may be loose or disconnected completely. I had my dash out a little while ago and when I put it all back together I had no indicators or hazards, it turned out that I hadn't replaced this connector.
HTH :)
Dan
