supra/aristo engine
dcarrter21
here's a list of all that's required to change from the bottom up.
Upper and lower sump are the opposite way around so you will need to put a supra one on.
Doing this also means you need to fit a supra strum as the aristo 1 is the wrong way around also.
Engine mount brackets are shorter that a supra so don't do what I did and lower the engine in before you notice.
I think the oil feed and drain configuration is slightly different but you should be able to leave that alone IIRC.
Water pump is totally different.
Don't know about the a/c and pas as the engine I bought came with them removed.
The intake and throttle body are also different as an aristo doesn't have the brake vacum pipe on top of the plenum.
The turbo pipes where the recurc valve goes is also different. With an aristo the recurc valve bolts directly onto the pipe other wise a supra has it attatched with a hose.
The wiring loom and the ecu are the same so there'd no need to change either of them.
Well that's about is. If there's anything I've forgot but I'm sure I havnt feel to edit the post.
