Big Ian Posted February 28, 2009 Share Posted February 28, 2009 any good, anyone used these type's of kit's? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=270323755987 i'm just looking for something to assist with cleaning up the polished rim on my alloy's, ive already stripped the clear coat of the rims (it was peeling) Link to comment Share on other sites More sharing options...
colsoop Posted February 28, 2009 Share Posted February 28, 2009 Its a bit expensive, i assume you were planning to run it off a drill ? If so 6" mops would probably work it a bit hard. Something like a 4" or maybe smaller mop would be better. You might be able to get away with just using soft mops depending on condition of the wheel. The alloy wheel kit would sort you out better than that large generic one from ebay. http://www.thepolishingshop.co.uk/acatalog/Standard_Polishing_Kits.html Link to comment Share on other sites More sharing options...
Big Ian Posted February 28, 2009 Author Share Posted February 28, 2009 yeah, i was going to use a drill, my rim's are not to bad .. since i removed the clear coat ive been cleaning them with fine wire wool and autosol and they clean up well, just some areas still have light stain's/water mark's and to help add to the overall finish before i re-clear them i thought one of these kit's might help and save a little time? ive seen 4" kit's for sale to thank's Link to comment Share on other sites More sharing options...
colsoop Posted February 28, 2009 Share Posted February 28, 2009 prices are still quite high though bud, and it doesn't look like it includes the pigtail either and those compounds are a bit of a general mix. Link to comment Share on other sites More sharing options...
Big Ian Posted February 28, 2009 Author Share Posted February 28, 2009 yeah .. there are other kit's on ebay that include the pig-tail and some have just the one grade of compound what compound would you recommend, it's mainly to shift the water mark's and try give a near mirror finish. thank's for your input Link to comment Share on other sites More sharing options...
Rob Posted February 28, 2009 Share Posted February 28, 2009 http://www.merlinabrasives.com/polishingkits.html Link to comment Share on other sites More sharing options...
jim Posted February 28, 2009 Share Posted February 28, 2009 After a lot of scotching/sanding/wetsand I used one of the kits from the polishing shop that Col linked to, it was my first time doing anything like that and it was really easy to use and my rims came up well considering how they were when I started. The optional extra belgom polish with the kits is a worthwhile investment too, easiest polish I've used and left them gleaming. Link to comment Share on other sites More sharing options...
Duffman Posted February 28, 2009 Share Posted February 28, 2009 After a lot of scotching/sanding/wetsand I used one of the kits from the polishing shop that Col linked to, it was my first time doing anything like that and it was really easy to use and my rims came up well considering how they were when I started. The optional extra belgom polish with the kits is a worthwhile investment too, easiest polish I've used and left them gleaming. http://i14.photobucket.com/albums/a315/evilbeemer/DSC00766.jpg Any before pics Jim? Link to comment Share on other sites More sharing options...
jim Posted March 1, 2009 Share Posted March 1, 2009 Just have a couple mate, but they're not the best quality and don't really show just how bad they were. I had to tape my fingers up by the time I got to the last one because I'd blisters on the tips of all of them. I've yet to find something that does a good job of sealing them though, I have to wetsand them with a very fine grit maybe every three months (they're hard to keep in the winter) and top them up with another hand polish with belgom alu. They're certainly not to everyone's tastes but I like them, although I've been thinking recently about painting my old ones black to see how it looks for a change, and if that doesn't work out then maybe sell both and put the money to some five spokes. If money was no object it would be a set of weds SA-67R in black chrome...I wish! Link to comment Share on other sites More sharing options...
colsoop Posted March 1, 2009 Share Posted March 1, 2009 yeah .. there are other kit's on ebay that include the pig-tail and some have just the one grade of compound what compound would you recommend, it's mainly to shift the water mark's and try give a near mirror finish. thank's for your input 1. colour mop (using the sovereign green) 2. white stich mop with sovereign green 3. Calico g and blue compound. It is hard to say for sure without seeing them in the flesh so always start with the least abrasive first and work from there. Don't move on to the next stage of polishing until the previous marks are gone. So start with the white stich mop and the sovereign green and see if that shifts the marks, if not go backwards to the colour mop. Don't mix compounds on the same mop. Attach the mop to the pigtail and get it running then loosely hold the compound to the mop for a couple of seconds, this will aplly some compound. Do this little and often. After you are happy with the finish clean the wheels with soap and water and a soft cloth trying not to add more scratches to the wheels. Dry then move on to the next stage and repeat. Wear eye protection and a mask and maybe somethign for your ears. I would also pop on some gloves as friction burns from those mops scar for life ! Link to comment Share on other sites More sharing options...
Big Ian Posted March 1, 2009 Author Share Posted March 1, 2009 thank's for the tip's guy's, i'll order from one of the 2 suppliers mentioned above and once ive got everything i'll post up my end result's not a great pic but this was my wheel's after i done my weekly clean (yesterday) with fine wire wool and compound http://memimage.cardomain.com/ride_images/3/2610/4381/31524690068_large.jpg Link to comment Share on other sites More sharing options...
