Gearbox inspection plate
Glosphil
My clutch is creaking a bit and I've oiled the pedal etc so its not that. I read I can spray some WD40 in the inspection plate and it should cure it.
Only thing is, where is the inspection plate? couldnt see anything under the gearbox, but then never seen one before, could someone describe where it is?
Thanks
