Glosphil Posted February 26, 2009 Share Posted February 26, 2009 My clutch is creaking a bit and I've oiled the pedal etc so its not that. I read I can spray some WD40 in the inspection plate and it should cure it. Only thing is, where is the inspection plate? couldnt see anything under the gearbox, but then never seen one before, could someone describe where it is? Thanks Quote Link to comment Share on other sites More sharing options...
bignum Posted February 26, 2009 Share Posted February 26, 2009 There`s 2, near the front of the box on the bottom of the bellhousing. Quote Link to comment Share on other sites More sharing options...
D8MOA Posted February 26, 2009 Share Posted February 26, 2009 both have 2 12mm bolts holding them on Quote Link to comment Share on other sites More sharing options...
merckx Posted February 26, 2009 Share Posted February 26, 2009 I read I can spray some WD40 in the inspection plate and it should cure it. You do know where to use the lubrication then? Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 26, 2009 Share Posted February 26, 2009 Is that a wise move spraying the clutch with lubricant? there must be another cause/solution for this creaking I personally would not spray in the housing with any lubricants Quote Link to comment Share on other sites More sharing options...
