hodge Posted February 25, 2009 Share Posted February 25, 2009 ive fitted veilside style intake and 90mm throttle body so havnt got the trac butterfly etc. Even if i remove the trac ecu altogether will i loose me manual and o/d off modes. I had a problem with the trac control last year which left my o/d light flashing. This wouldnt let me select manual or o/d off mode til i fixed it. Quote Link to comment Share on other sites More sharing options...
bondango Posted February 26, 2009 Share Posted February 26, 2009 IIRC you will loose manual mode as the ecu reports a coms problem to the trac ecu if you remove it. Plug in the Trac ECU. Remove the throttle sensor from the Trac throttle and plug it back onto the loom. You will need to jam the sensor ito the open position (remove spring) - and you should be good to go Quote Link to comment Share on other sites More sharing options...
hodge Posted February 26, 2009 Author Share Posted February 26, 2009 could i not just plug in the tps into the sub tps as it works the oposite way aroud. Quote Link to comment Share on other sites More sharing options...
bondango Posted February 26, 2009 Share Posted February 26, 2009 (edited) If you plug your tps into the sub tps then your ECU wont get a throttle signal (and will also throw a code) just remove the sub tps sensor from the old throttle housing, jam it so its fully open, and plug it back into loom. The trac ecu will think its still in place and working normally Edited February 26, 2009 by bondango (see edit history) Quote Link to comment Share on other sites More sharing options...
hodge Posted February 26, 2009 Author Share Posted February 26, 2009 ok will do cheers for the help fella. Quote Link to comment Share on other sites More sharing options...
j80leo Posted November 17, 2009 Share Posted November 17, 2009 Can this be done on a auto? as i am thinking of doing this to my car, also thinking of removing the water pipes underneath do you simply connect the 2 pipes together? Quote Link to comment Share on other sites More sharing options...
hodge Posted November 17, 2009 Author Share Posted November 17, 2009 Yep that's right or either just block the 2 pipes off. Quote Link to comment Share on other sites More sharing options...
j80leo Posted November 18, 2009 Share Posted November 18, 2009 Have you had any problems with it been an auto fella. Quote Link to comment Share on other sites More sharing options...
