Guest chris mccarthy Posted February 25, 2009 Share Posted February 25, 2009 dropped the car off this morning for a service and to have the gear box oil changed and the filter's in the box clean/changed and when the mechanic has taken the sump of there was a screw, a spring and a little bearing dropped out he's found where the spring and screw go but cant see where the bearing goes he said its in a plastic casing has anyone any ideas cheers Quote Link to comment Share on other sites More sharing options...
Terminator Posted February 25, 2009 Share Posted February 25, 2009 Oh that is not good, that sounds like the contents of one of many valves in the box. You will need an auto box specialist to look at the box. Ask Chris Wilson he knows a good one. To be honest you may be better off getting a second hand box, as your box will probably have to be striped which will be many hours work so big £'$ Quote Link to comment Share on other sites More sharing options...
Guest chris mccarthy Posted February 25, 2009 Share Posted February 25, 2009 that aint dont sound good cheers pal Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 25, 2009 Share Posted February 25, 2009 I know a good auto box man in Crewe. Search on Autolock Transmissions, Macon Way. He has the patience of a constipated rattlesnake, so don't expect a blow by blow account of how your man can fix it.... Quote Link to comment Share on other sites More sharing options...
Guest chris mccarthy Posted February 26, 2009 Share Posted February 26, 2009 ok cheers hes got it back together this morning and seems be running ok with all the parts back in place lol cheers for your help Quote Link to comment Share on other sites More sharing options...
