Peter P Posted April 5, 2009 Author Share Posted April 5, 2009 I was just reading through this but couldn't see if you had decided on an engine yet. Going to go with an early non-VVTi 1JZ with a Garrett GT4088R for company! Should be a good combination. Cheers. Pete Link to comment Share on other sites More sharing options...
bondango Posted April 5, 2009 Share Posted April 5, 2009 Ahem...GT4067R Link to comment Share on other sites More sharing options...
Peter P Posted April 5, 2009 Author Share Posted April 5, 2009 Ahem...GT4067R Wondered where you'd gone! Ok maybe a GT4067R then! Link to comment Share on other sites More sharing options...
bondango Posted April 6, 2009 Share Posted April 6, 2009 The Precision GT4067r is going to be most peoples weapon of choice, dont let the numbers fool ya GT4088R - tts a GT40 turbine wheel which is 77mm and 73 trim , 88 means that the EXDUCER is 88mm 54 trim and Inducer is 64.7mm and the compressor housing is .72 A/R GT4067R - bit of a sting this one..still the same on the GT40 portion, the turbine wheel again 77mm and 73 trim. Here is the Sting... the 67 means this turbo has a 67mm Inducer and 84.07mm Exducer You move with a smaller A/R on the hotside to improve spool time on the 1jz, but the turbo still has the legs of the 88R at the top end becuase of the frankenstein trim Link to comment Share on other sites More sharing options...
Peter P Posted April 6, 2009 Author Share Posted April 6, 2009 The Precision GT4067r is going to be most peoples weapon of choice, dont let the numbers fool ya GT4088R - tts a GT40 turbine wheel which is 77mm and 73 trim , 88 means that the EXDUCER is 88mm 54 trim and Inducer is 64.7mm and the compressor housing is .72 A/R GT4067R - bit of a sting this one..still the same on the GT40 portion, the turbine wheel again 77mm and 73 trim. Here is the Sting... the 67 means this turbo has a 67mm Inducer and 84.07mm Exducer You move with a smaller A/R on the hotside to improve spool time on the 1jz, but the turbo still has the legs of the 88R at the top end becuase of the frankenstein trim What he said!!! :p;) Sounds awesome! Pete Link to comment Share on other sites More sharing options...
JamieP Posted April 17, 2009 Share Posted April 17, 2009 Peter do you know if the 2jz turbo kits fit the 1jz engine? cheers. Link to comment Share on other sites More sharing options...
bondango Posted April 17, 2009 Share Posted April 17, 2009 jamie, the oil feed/return hardware is the same but the manifolds are different though. There was a single kit from vortex/boostlogic that could be modified to fit though http://www.lexusclub.co.uk/pic22.jpg but with 1jz manifolds plentiful these days theres no point Link to comment Share on other sites More sharing options...
JamieP Posted April 17, 2009 Share Posted April 17, 2009 Ok thanks, who makes a 1jz t4 tubular manifold? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted April 17, 2009 Share Posted April 17, 2009 I can get one made if needed. Link to comment Share on other sites More sharing options...
bondango Posted April 17, 2009 Share Posted April 17, 2009 Well you have your cheap and cheerful ebay manifolds (Greddy copies), Theres also a few known as the zoonwen/Drewgo manifold which look like this http://img.photobucket.com/albums/v325/zoonwen/DSC00039.jpg which are china knockoffs BUT very very highly rated in the 1jz world.. then you can have quality long runner manifolds for thew likes of MTR http://us.st12.yimg.com/us.st.yimg.com/I/yhst-63817110493093_2040_46173336 And you can have one designed around your turbo choice and wastegate setup for £200 ..think i posted details in another thread. Link to comment Share on other sites More sharing options...
JamieP Posted April 17, 2009 Share Posted April 17, 2009 Cheers guys. Link to comment Share on other sites More sharing options...
safcdixon Posted April 21, 2009 Share Posted April 21, 2009 hi what gearbox you gonna use the r154? do ya know the proper code for the 154 box ive found a box for my conversion but not sure if its the right one the code on it is WXJZ 1 its a manual 5speed cheers bud Link to comment Share on other sites More sharing options...
Peter P Posted April 22, 2009 Author Share Posted April 22, 2009 hi what gearbox you gonna use the r154? do ya know the proper code for the 154 box ive found a box for my conversion but not sure if its the right one the code on it is WXJZ 1 its a manual 5speed cheers bud Hi, Yes I will be going with the R154 5 speed gearbox but not sure on the code i'm afraid! Think there is a post on the 2jzswap.com forum that shows some identifying factors to determine if you have the correct box? Try this: http://www.2jzswap.com/vbulletin/showthread.php?t=2427 All the best with it mate! Pete Link to comment Share on other sites More sharing options...
Peter P Posted May 6, 2009 Author Share Posted May 6, 2009 Quick question I did post under the wanted section but have had no joy with so far! I've just sourced an engine stand for my 1JZ but need to know what size/type bolts to get to attach the two together?? Someone told me it's gearbox bolts but are these the same for the 2JZ or something different?? Need to get the engine collected asap so all help gratefully received! Cheers. Pete Link to comment Share on other sites More sharing options...
ray007 Posted July 12, 2010 Share Posted July 12, 2010 hows this project going? Link to comment Share on other sites More sharing options...
Guigsy Posted July 12, 2010 Share Posted July 12, 2010 wow... been away for the weekend. what a plank that guy was. since when was a strip down to fix a problem and then being put back together again not a rebuild. good luck with the project. subscribed Link to comment Share on other sites More sharing options...
