d-_-b Posted February 24, 2009 Share Posted February 24, 2009 (edited) Ok, after having my first question answered so promptly, turned out i was being a pleb ^^ thought insted of creating another post would just edit this one could the distributer cap be causing rough running issues? Edited February 24, 2009 by d-_-b (see edit history) Quote Link to comment Share on other sites More sharing options...
Alex Posted February 24, 2009 Share Posted February 24, 2009 (edited) You have an NA, it uses a distributer not coil on plug (coil pack) ignition. Dizzies can need cleaning and checking inside - it's the black circular unit on the front left of the engine. If you are not comfortable woth this sort of maintenance take it to a trained mechanic, dizzies on all engines are basically the same. You would be best to try new sparkplugs and a cleaned/refreshed dizzy, then if this doesn't clear things up you'll have eliminated some relatively cheap fixes. You can see which sparkplugs you should use in the FAQ - You're looking for grade 5 plugs AFAIK. Edited February 24, 2009 by Alex (see edit history) Quote Link to comment Share on other sites More sharing options...
Alex Posted February 24, 2009 Share Posted February 24, 2009 Yep these ones. Normally Aspirated NGK - Standard - BKR5ES-11 (2382) - gap is already 1.1mm at the "-11" signifies they should be set to this already. Quote Link to comment Share on other sites More sharing options...
d-_-b Posted February 24, 2009 Author Share Posted February 24, 2009 (edited) Thanks alex for the quick reply, youve been very helpfull! Edited February 24, 2009 by d-_-b (see edit history) Quote Link to comment Share on other sites More sharing options...
