Six Jenvey throttle bodies on Racecarsdirect
Chris Wilson
In light of recent talk about multiple TB conversions here are some bargain 45mm throttle bodies to base a conversion on. Be assured that without a sophisticated mappable ECU you won't get far, as multi TB's on boosted engines can be a bear to map. The response will be a lot better though.
http://www.racecarsdirect.com/listing/23069/45_mm_jenvey_SF_throttle_bodies.html
Is the reason they are more responsive that when they open the air flow is straight into the cylinder where as with a single throttle the entire plenum has to be filled 1st? Is that why big inlets like the Greddy are a little bit trickier to get the throttle tip in working sweetly when mapping?
they look nice but the linkages look to wide to fit on the supra cylinder spacings unless you made an adaptor piece to space them out, the other problem i can see is the injector angle looks wrong as the supra head is virtually a side draught these look more suited to a down draught setup, nothing insurmountable though, not quite as bargain bucket as my M3 ones though ;)
