wile e coyote Posted February 23, 2009 Share Posted February 23, 2009 Does the supra have baffles in the fuel tank ? Reason i ask is when im low on fuel and give it beans it runs out of fuel cuts out then its ok when driving nornaly which is a right pain so i have to make sure i have atleast 1/4 of a tank Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 24, 2009 Author Share Posted February 24, 2009 Anybody ? Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted February 24, 2009 Share Posted February 24, 2009 something is wrong there I think, I dont know if the tank has baffles or not but cutting out just because you give it some stick when your under a 1/4 tank sounds wrong. Quote Link to comment Share on other sites More sharing options...
Ark Posted February 24, 2009 Share Posted February 24, 2009 Maybe that's the problem - when the car's short on fuel, it's not beans you should be giving it... It shouldn't start cutting until well after the low-fuel light is on, but I don't know about baffles. Quote Link to comment Share on other sites More sharing options...
JustGav Posted February 24, 2009 Share Posted February 24, 2009 There is a small moulded area which I suppose could do that function... The trick is probably to make sure you have a bit more fuel Quote Link to comment Share on other sites More sharing options...
markssupra Posted February 24, 2009 Share Posted February 24, 2009 1. Fuel filter 2. pump output pipe inside tank split. I had a similar prob about 4 years ago, found the pipe connected to the pump output had a split in it and was just spraying out fuel inside the tank and not getting to the engine, good for the fuel consumption though Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 24, 2009 Author Share Posted February 24, 2009 Ok cheers guys this only happens when low on fuel just before light comes on Ill check the pump assembly (suposed to have had an uprated 1 before i got it but not convinced it was done) Got a filter in garage just need to get it done Quote Link to comment Share on other sites More sharing options...
