injectors 440 550 for n/a engine where to buy?
Guest ziuziu007
Guest ziuziu007
hi,any one know where to get direct fit injectors for jap spec n/a engine? i am after 440 or 550 ,or will the injectors from tt fit to n/a?thanks:search:
  • 2 months later...
Guest ziuziu007
Why do you need bigger injectors? The TT injectors won't fit the NA rail.
i just done single t on n/a,got 305 lph external fuel pump so now looking for bigger injectors.
Guest ziuziu007
Are you going N/AT then? otherwise you're wasting your time and money, sorry can't help as to whether they fit or not, but i'm sure there will be an N/AT owner along soon.
yeh,just done the conversion,got single t and external 305 lph fuel pump,so need the injectors now to make it all good.
or try here: http://www.clubna-t.com full of good info. the gen 2 or 3 i cant remember RX7 injectors fit.
http://forum.clubna-t.com/showthread.php?t=6485&highlight=injector
resistor pack:
http://forum.clubna-t.com/showthread.php?t=3583&highlight=injector
hope that helps. any questions feel free to ask mate.. what ecu mod are you running?
