scooby999 Posted February 23, 2009 Share Posted February 23, 2009 What is the metal prong sticking out of the pads on the jspec. Its the inner pad both sides. Mine is fouling on the caliper so will this cause a problem or will i need to bend it out the way? Paul Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted February 23, 2009 Share Posted February 23, 2009 im sure its the outer pad on mine... and didnt get in the way? maybe you have them on the wrong side? Quote Link to comment Share on other sites More sharing options...
scooby999 Posted February 23, 2009 Author Share Posted February 23, 2009 lol, probably but took them off the way they went off so person before must have fitted em wrong. Prob why they are jamming an binding Quote Link to comment Share on other sites More sharing options...
scooby999 Posted February 23, 2009 Author Share Posted February 23, 2009 Just read the guide, see pic, and ive done it as per that so the metal notch on the pad is on the inside Notch seen on pad here: Does this go top or bottom of the caliper? Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted February 23, 2009 Share Posted February 23, 2009 Maybe its different on the fronts, but im sure when I changed my rears the other day that lil metal bit was on the outer pad, and at the bottom I think? Is it only on 2 of the 4 pads? or all 4? Quote Link to comment Share on other sites More sharing options...
scooby999 Posted February 23, 2009 Author Share Posted February 23, 2009 Just 2 mate and got the tabs at the top. They are wedge onto the caliper itself. I will swap them over the wknd so the tab is at the bottom both sides and see how that goes. Must have got something wrongs as they were smoking whne i got back from a short run lol Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted February 23, 2009 Share Posted February 23, 2009 yeh id try swapping left for right so that the tab is at the opposite end, see if that helps Quote Link to comment Share on other sites More sharing options...
Homer Posted February 23, 2009 Share Posted February 23, 2009 IIRC the first pic you posted looks correct, the pad needs to sit inside the tabs. If you have fitted them correctly and they are overheating are you sure you don't have a stuck slider? And make sure you use some copper grease and fit the anti-squeal shims! Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted February 23, 2009 Share Posted February 23, 2009 IIRC the first pic you posted looks correct, the pad needs to sit inside the tabs. If you have fitted them correctly and they are overheating are you sure you don't have a stuck slider? And make sure you use some copper grease and fit the anti-squeal shims! and anti-squeal springs! Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted February 24, 2009 Share Posted February 24, 2009 the metal tab you speak off is the wear indicator, its designed to rub on the disc and make a noise when the pads get low, so you wont cause any problems by bending it slightly, just make sure it will still contact the disc before the pad wears away Quote Link to comment Share on other sites More sharing options...
scooby999 Posted February 24, 2009 Author Share Posted February 24, 2009 The old pads didnt have the anti squeal bits fitted? I think the wear indicator is fouling on the caliper so could be causing it not to return properly. cheers guys, will check sliders too Quote Link to comment Share on other sites More sharing options...
