720p Xbox to new telly??
Havard
Hi,
Thought I'd ask on here as a lot of bods seem clued up on telly's. I have moved my xbox into my extension and have bought a Toshiba 37" LCD. The TV is HD Ready 720p but when I put my xbox into 720p mode then eveything on the screen goes a wee bit smaller and when playing the games, everything looks like it's been made thinner.....:rolleyes::(
If I put it back to 480p then everything is ok but I want to use the TV to it's full potential. In 480p the xbox gives me options for "normal" or "widescreen" operation. It looks correct in "Normal" but a bit wierd in "Widescreen".
When I change to 720p it will only allow me to use "widescreen" and the picture doesn't look quite right again..!!:blink: On the TV it will only allow me to play in "widescreen" or "4:3" and then it just gets really silly!!
I am connected via the 5 cables on the standard AV/HD cable that comes with the xbox. What I want to know is, do you have to make your TV aware that you are using 720p and should I just buy a HDMI cable and hope that it sorts the picture out??
H.
I have a problem sort of similar however when i turn my xbox settings to run 720p and flick the VGA cable over to HDTV the screen goes blank until i flick the switch back over however i can still hear the home screen even though the screen is blank??!!
Any suggestions or should i just buy and HDMI cable and be done with it??
Just seems abit stupid how they have a switch to turn it to HD through the VGA cable and it doesnt work and they dont supply an HDMI cable with it :blink:
i had a bit of a "WTF" moment when i went from 1080p to 720p when i moved my xbox to the bedroom. But after i changed the setting in the settings for HD on the xbox it was all fine and im useing the component cable.
I can only imagine its just a setting somewhere that doesnt match up with the xbox correctly
Well, went to get a HDMI cable today.....:)
Thge resolution is absolutely fantastic but the shape of the screen isn't right for me. I have played COD for 7 months in 480P mode and loved it. The picture is now crystal clear but all thye streets now look like alleyways.......:blink:
I think I'll just go back to 480p...FFS!!
H.
