Question for anyone with a copy doluck front on there supe
brians25
Do you have to fit the rubber strip to the top edge of the bumper , where the bumper meets the bonnet or do you leave it off, i have looked at pics of others on the forum but i cannot eif the strip has been left in place.
and if so does anyone have a part no for it.
Thanks
B
If they do cost a fortune would imagine if you were to buy a secondhand seal, you could cut a length to match that bit and have spare over. It is literally just a length of rubber seal. Bond it to the bolt heads with some silicone bond type stuff and done.
It is a very good idea to replace it, as it stops air and crap going up under the bonnet.
Give Keron or Jezz a P'm, I am sure they will have a few lying around.
If you drill out a couple of extra holes to allow the mounting bolts for your bumper to go through the aluminium (that holds the rubber), you can get it to fit as it did from the factory;)
think i'll price it from steve manley an just fit it cos it's supposed to be there, as long as it isn't £329.99
Think the rubber bit is about 30 notes.
If you look up the US IPC the prices are in there. Just take what it says in $ as £'s. It usually works out that way.
