Most lightweight single/dual plate clutch/flywheel combo?
halllon
Hello guys,
What is the most lightweight single or dual plate clutch and flywheel combo out there?
I have had an ORC (Ogura) dual plate clutch combo weighing in at ~13.5kg (IIRC) but I want to try a lighter combo, preferably below 10kgs. I know the Tilton 4-plate combo with the 1st gen flywheel weighs in below 5kgs (2nd gen is ~7kgs?), but the Tilton one is out of my range cost wise.
The clutch has to have a "street spec" compound such as SPEC stg 1/2+ and regular ORC clutches which can handle substantial slippage/modulation as the car is used for drifting. The car is roughly 500fwhp/750fwnm.
Please let me know if you have any recommendations. I don't mind swapping makes, e.g. SPEC clutch and ACT flywheel etc.
All info appreciated! :)
Cheers.
Cheers Wez, I've had a look on this site: http://www.osgiken.net/products/racingmultiplate.html
They have pretty light flywheels, but their regular clutches seem to be too heavy for what I am looking for. The lightest OS Giken clutch/fw combo is 14.4 kgs which is even heavier than the ORC I have today.
Does anyone know the approximate weight of the stock 2JZ-GTE clutch, or the weight of comparable single plate clutches (SPEC, ACT, Exedy, etc.)?
Maybe a good single plate mated to a further lightened Fidanza flywheel would be a a good and affordable solution...
