Dragonball Posted September 18, 2002 Share Posted September 18, 2002 Guys I have a jap spec - so just checking that 550 high impedance will direct replace? How much can I look to pay and where from recommended (Nippon Denso's?) Cheers Paul:cool: Link to comment Share on other sites More sharing options...
mazman Posted September 18, 2002 Share Posted September 18, 2002 dont the jap spec have 430cc low impedance?,if so i think you'll need some resistors. try a search on it Link to comment Share on other sites More sharing options...
Branners Posted September 18, 2002 Share Posted September 18, 2002 the 550cc injectors will need the UK spec resistor pack. Mostly turns out cheaper to buy new from the US than trying to find them second hand in the UK. JB Link to comment Share on other sites More sharing options...
Dragonball Posted September 18, 2002 Author Share Posted September 18, 2002 The ones I am looking at are Nippon denso n19550-2020 high impedance Any info on these guys? Cheers Paul:cool: Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2002 Share Posted September 18, 2002 Is that the correct part number Paul? Do you have any ideas on where to get them from. I recently got some Denso spark plugs locally, so maybe they can get the injectors too... - Don't they do 650's as well? Link to comment Share on other sites More sharing options...
GavinL Posted September 18, 2002 Share Posted September 18, 2002 Hi... If you do a search there is loads of info/parts numbers on the injectors & packs. You should also find prices and details of Jay marks in the US who do a good deal on price and delivery. Link to comment Share on other sites More sharing options...
Nic Posted September 18, 2002 Share Posted September 18, 2002 How easy is it to set up the fueling on a J-spec with the bigger UK injectors and pump fitted? Can an A/F controller easily be set to do the job or does it require dynoing? If it is a relatively easy job to set them up, then I'll look at the costs of parts here. if I can get them cheaper than the US (which I should be able to do I suspect) then I might be able to organise a group buy if there is enough interest. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted September 18, 2002 Share Posted September 18, 2002 Kevin, the chap who bought my Kawasaki blue supra, has UK spec 550cc injectors for sale. Let me know, if you need his contact details. Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2002 Share Posted September 18, 2002 Does anybody know of any reason why a set of 550cc side fed high impedence injectors would work less efficiently than 550cc low impedence injectors with a resistor pack? Obviously the J-spec is designed to run high impedence injectors, so fitting a set of high impedence injectors and a high flow fuel pump should work as well as upgrading to UK spec without the agro of fitting the resistor pack... I know you'll need some kind of A/F unit to sort out how much fuel and when etc. Am I missing something? ps. Excuse me if I've got this totally wrong, I normally fit car alarms, not fuel injection Link to comment Share on other sites More sharing options...
Need4Speed Posted September 18, 2002 Share Posted September 18, 2002 I was discussing the injector issue with an ECU expert recently who asked the question "what do you do to modify the duration when fitting larger injectors?" Does anybody know the answer to this? I assume he's refering to the fact that bigger injectors with the same duration as standard injectors will over-fuel. Don't look at me, I'm a carb man! Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2002 Share Posted September 18, 2002 Things like the Apexi AFC. There's loads more variations but that's just the first one to come to mind as I've been reading up on how it works. You generally use them to trim down the injectors opening duration at lower rpm where the fuelling was ok and let the duration get longer, (more fuel), as the revs climb, (or when needed). Ian C did a very good detailed post recently on this subject. Sometime over the last couple of weeks I think... Again, someone let me know if I've got this wrong:rolleyes: Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 18, 2002 Share Posted September 18, 2002 I think it be mentioned but you want side feeds as a direct replacement. There is no reason they won't work with a SAFC or similar. You also want to check the fitment as not many standard injectors will fit our stock rails. Link to comment Share on other sites More sharing options...
randy Posted September 18, 2002 Share Posted September 18, 2002 Too much hassle hooking up the resistor pack etc If you have high impedence injectors stick with it. I checked with a couple of tech guys they say there is no problem using the High Impedence injectors on our jap spec cars which came with the 440cc. There is a company called POWER of japan that sells high impedence injectors in 550cc 680cc and 720cc. Link to comment Share on other sites More sharing options...
mark brown Posted September 18, 2002 Share Posted September 18, 2002 After speaking with a Guy I have known for years who appears to be a fuel injection guru, he advises me that high impedance injectors react to ECU commands faster than low impedance and therefore pulse width is more controllable. Mark Brown Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2002 Share Posted September 18, 2002 Right, loads of questions... 1, Other than injectors, AFC or similar and fuel pump. What else is required? - (Parts only, I know I'll have to get someone that knows what they're doing to set it up) 2, Would you need a larger fuel rail for anything over 550's? 3, Is there anyone in the UK that sells these injectors? - Are they Nippo Denso products 3a, Are there any cars that anyone knows of that run high impedence side fed 550's as standard? - Lexus V8? 4, Has anybody gone down this road before, using high impedence injectors? 5, How many people on here are looking at upgrading fuel systems very soon? - I know Graham Rudd is looking into this now and obviously Paul E, (sorry for hi-jacking your thread Paul ), as Nic suggested, a group buy may be in order, then a group set up session . 6, Nic have you heard of the company Randy mentioned 'Power'? Can you find out if prices are better over there for us? Link to comment Share on other sites More sharing options...
Graham Rudd Posted September 18, 2002 Share Posted September 18, 2002 Do I sense a group buy coming on? Yep, as Matt says I'm also looking at getting my fueling upgraded very shortly. I think I'll go for larger than 550's though, if I'm going to upgrade I figure I might as well future proof and make sure I only have to do it once. I'd like to know what someone like CW's views are on the best upgrade path for fuelling. I pretty much want to get my car ready to accept a big single or the HKS twins. I'm also looking into aftermarket ECU's instead of buying a fuel computer. Terry, have you gone down this route? Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2002 Share Posted September 18, 2002 I have to confess, I was looking at the 680's myself. Hence the querey of needing a larger fuel rail ... Help required... Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 18, 2002 Share Posted September 18, 2002 I did think about it Graham but then got a standalone which will support either type of injector. RC engineering can make up 680cc High Impedance injectors that will fit the rail, but they are not too good when it comes to responding to e-mails. Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 18, 2002 Share Posted September 18, 2002 Originally posted by Matt Harwood I have to confess, I was looking at the 680's myself. Hence the querey of needing a larger fuel rail ... Help required... You don't need a bigger fuel rail. The only reason for changing fuel rail is to get cheaper injectors but they will be top feed. Link to comment Share on other sites More sharing options...
randy Posted September 19, 2002 Share Posted September 19, 2002 Originally posted by Terry Saunders I did think about it Graham but then got a standalone which will support either type of injector. RC engineering can make up 680cc High Impedance injectors that will fit the rail, but they are not too good when it comes to responding to e-mails. They took a month to reply to me regarding their injectors? I think you guys would be better of using the 720cc injectors with a Apex S-AFC and a 255ltr walbro pump(I have one)! As this would take care of your single turbo upgrade! Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 19, 2002 Share Posted September 19, 2002 Does anybody have a telephone number for RC engineering? I'd be surprised if they didn't answer their phone! Paul, where did you get that Denso part number from? Link to comment Share on other sites More sharing options...
Dragonball Posted September 19, 2002 Author Share Posted September 19, 2002 From supplier in states I queried the high impedance on 550's but confirmed they were Paul:cool: Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 19, 2002 Share Posted September 19, 2002 Originally posted by randy a 255ltr walbro pump(I have one)! As this would take care of your single turbo upgrade! I have two:p One pump is no better than a stock UK pump. Be careful. Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 19, 2002 Share Posted September 19, 2002 Originally posted by Terry Saunders I have two:p One pump is no better than a stock UK pump. Be careful. Still better than a J-spec pump ! Where did you get yours from and when you say be careful, do you mean that there are more than one type of pump or that some are better than others? Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 19, 2002 Share Posted September 19, 2002 Walbro do various pumps, but none that actually flows more than a UK Bosch pump( CW sells a bosch internal that will flow more). The only reason I used two Walbros is that they draw less amps than the UK so are easier on the stock wiring when running 2. They are also noticably louder than a UK pump. Randy's statement scares me a little. Yes you can run a single on one internal pump but not a big single & you would need to be very careful what boost pressures you run. I would also want a constant overview of the A/F's. Always go for a safe option. Leon sells Walbro's CW gets great prices on UK Bosch pumps. Link to comment Share on other sites More sharing options...
