Glosphil Posted February 21, 2009 Share Posted February 21, 2009 I bought 3 of the bolts for the manifold where the 1st cat goes because my decatt pipe was gassing and I couldnt do them up anymore. I've removed 2, but the lower one is now rounded off at the tip and on the nut and I cant turn it. I've had a look at taking the manifold bit off, and removed the bracket and the air sensor but the 3 (are there 3) nuts I can see I cant get to because the decatt pipe is still on. anyone got any good ideas? I've been at it hours and I'm totally stuck Cheers Quote Link to comment Share on other sites More sharing options...
merckx Posted February 21, 2009 Share Posted February 21, 2009 I bought 3 of the bolts for the manifold where the 1st cat goes because my decatt pipe was gassing and I couldnt do them up anymore. I don't follow, the front of the 1st decat fit's onto the turbo elbow with 3 studs and nuts. If you're having a problem here you can remove the turbo elbow which isn't difficult, removing the turbo heatshield will give you access to the nuts/bolts (I can't remember if they're all nuts as it's been a while since I removed mine). Quote Link to comment Share on other sites More sharing options...
