hodge Posted February 21, 2009 Share Posted February 21, 2009 I know the PAS resevior has 2 different size pipes. the larger pipe of the 2 has a 16mm o/d. But it reduces to 10mm when it enters the pump. The smaller pipe of the 2 I would assume would just be a -6an fitting. I have to relocate the resevoir due to a large aftermarket intake. Cheers in advance guys. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 21, 2009 Share Posted February 21, 2009 Why weld anything on? Just use push on hoses, but longer, as standard. There's a gauze filter in the bottom of the reservoir and I *THINK* it's nylon. Welding may reduce it to a molten mess. Quote Link to comment Share on other sites More sharing options...
Terminator Posted February 21, 2009 Share Posted February 21, 2009 I had to move mine to make way for a bigger plenum. I just used the stock hose sizes, just a bit longer, as Chris said. Adding -AN fittings to the PAS system just adds unnecessary weight.IMHO Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 21, 2009 Share Posted February 21, 2009 And, if you put Aeroquip threaded fittings at the reservoir end, what about the other ends of the pipes? Too needlessly complex! Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 21, 2009 Share Posted February 21, 2009 How about this PHR Chrome plated one? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 22, 2009 Share Posted February 22, 2009 I know the PAS resevior has 2 different size pipes. the larger pipe of the 2 has a 16mm o/d. But it reduces to 10mm when it enters the pump. The smaller pipe of the 2 I would assume would just be a -6an fitting. I have to relocate the resevoir due to a large aftermarket intake. Cheers in advance guys. Should be -8 and -12 I think. Quote Link to comment Share on other sites More sharing options...
hodge Posted February 22, 2009 Author Share Posted February 22, 2009 The problem is really the fitting on the power steering pump. The part the hose fits onto is just too long and hits the plenum. So it I was gona shorten it anyway I thought I might as well go for a threaded fitting. I didnt realise about the gauze in the bottom of the tank Chris cheers for that. That tank does look mighty fine jamie but im abit reluctant to fork out 180 quid for one when I can weld the fittings on and polish it myself. Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 4, 2009 Share Posted March 4, 2009 That tank does look mighty fine jamie but im abit reluctant to fork out 180 quid for one when I can weld the fittings on and polish it myself. Mine is a lot less than that, check out the parts for sale section if you are interested. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 4, 2009 Share Posted March 4, 2009 Why not just buy one of my alloy ones? http://garagewhifbitz.co.uk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=7345&category_id=2318&option=com_virtuemart&Itemid=53 Quote Link to comment Share on other sites More sharing options...
hodge Posted March 6, 2009 Author Share Posted March 6, 2009 all sorted now. I modified the pickup on the pas pump. Will post some pics of the single build up soon. Cheers for the help Quote Link to comment Share on other sites More sharing options...
