Clear front light part no's...
Gaz Walker
Gaz,
Are you talking of the front turn signals?
*#81510-80086(Frt.T/S Lamp,RHS): 5,800 JPY
*#81520-80086(Frt.T/S Lamp,LHS): 5,800 JPY
If you have ordered the turn signal you need the harness!
t/s frt harness -#81515-14390[97-98 pig tail for aftermarket lamps]
Randy:)
Originally posted by randy
Gaz,
Randy:)
Excuse my complete ignorance, but...
1) I assume you need two of the same harness (do you get two in the one part number?)
2) Do they just plug in, or is it more complicated?
I don't think I used a harness as you have to splice the wires.
The connector that comes on the new set has power for the incorporated sidelights as well so its a bigger connector.
We just chopped the end off each and wired the indicators back up...with more time and patience I would have run another wire to the additional side lights, from the originals in the main headlight cluster.
Originally posted by gazwalker
Randy,
I would like the part numbers for anything to swap these:
Gaz,
Those are the 97-98 turn signals!! The ones I gave you the part nos of-
Please note-- Only one of them comes with a harness that is the right hand side one. The other one on the left is the one you need the harness for. Hence unless you plan to make a custom harness which I did{Pain in the ASS} I suggest you buy the harness for the left. Part no is above.
:D
