hp006 Posted February 19, 2009 Share Posted February 19, 2009 Major help needed!!!! I put a new radio in the supe fine, worked as it should no problems. I then changed the oil filter (big fight) and have lost all electrics, no horn, windows, lights nothing. Have i knocked something around the oil filter that would cause me to loose all power. I have used the radio harness so thats fine and its a TT. The battery is fine and fully charged. Checked the fuses under the hood and the drivers footwell all correct. Is there one big fuse that does the power to the whole car? Does'nt even try and start. Quote Link to comment Share on other sites More sharing options...
j80leo Posted February 19, 2009 Share Posted February 19, 2009 Try the earth on the battery or positive to see if they are loose? Quote Link to comment Share on other sites More sharing options...
hp006 Posted February 19, 2009 Author Share Posted February 19, 2009 Have checked that, they are fine, i also just put a battery charger on the car. The charger goes from showing full to low back to full. Never had it do this before. Keeps setting the alarm off as well. The alarm goes on full for 3-4 secs then sounds like it has died then starts the process over again Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted February 19, 2009 Share Posted February 19, 2009 is there an Engine earth anywhere near the oil filter, maybe you have knocked it off Quote Link to comment Share on other sites More sharing options...
j80leo Posted February 19, 2009 Share Posted February 19, 2009 Try charging the battery for a while and then test all the other electrics to see if any are working, you might have a loose earth somewhere on the car body. Quote Link to comment Share on other sites More sharing options...
