pjavon Posted February 17, 2009 Share Posted February 17, 2009 Hi Trying to split my J-spec headlights for a bit of a clean up but can't seem to get them apart. Have had them in the oven for about 5mins and are quite hot to the touch but they still seem stuck, the plastic back seems to have started to distort before the glue/bonding is melting. I am trying to seperate at the right place aren't i Any help please Quote Link to comment Share on other sites More sharing options...
AlexM Posted February 17, 2009 Share Posted February 17, 2009 I haven't done it myself, but there's a good guide here if that helps. Quote Link to comment Share on other sites More sharing options...
3LL Posted February 17, 2009 Share Posted February 17, 2009 mine took about 20 mins each to slowly pry apart. i used two long neck flat head screwdrivers to prize them slowly, bit by bit. it took more force than I was expecting to use on something as fragile as a light, but hey came apart fine once i was 3/4 round them. Just make sure the area your seperating is hot and take your time. Quote Link to comment Share on other sites More sharing options...
magictorch Posted February 17, 2009 Share Posted February 17, 2009 Try using a hairdryer if its starting to set again Paul...take it easy tho Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 17, 2009 Share Posted February 17, 2009 what temp is the oven? 150 deg c for 7 min should do it mate Quote Link to comment Share on other sites More sharing options...
Stonkin Posted February 17, 2009 Share Posted February 17, 2009 get a screwdriver and kitchen knife in there and pull them apart! Quote Link to comment Share on other sites More sharing options...
Homer Posted February 17, 2009 Share Posted February 17, 2009 They need to be pretty hot, even to the point of being almost too hot to handle with bare hands. I've done 3 sets now and about 10-12 minutes at 150 degrees is needed (pre-heated of course). Just make sure the edges are not touching anything or in a hot spot. Check every few minutes to make sure there are no signs of clouding on the lens. Looking at your pics, you're on the right track, but they've just not been heated enough to soften the sealer enough get a screwdriver and kitchen knife in there and pull them apart! Yep, a large flathead screwdriver does the job nicely to pry them apart Quote Link to comment Share on other sites More sharing options...
pjavon Posted February 18, 2009 Author Share Posted February 18, 2009 Thanks for the advice everyone, will try again after the weekend. Got the exhaust on J, sounds great i'm really happy with it:d:d Might see you on sunday, if i haven't broke my headlights by them:( Paul Quote Link to comment Share on other sites More sharing options...
Duffman Posted February 18, 2009 Share Posted February 18, 2009 100deg for 10 mins should do it..done mine the other week...started at the top side...once you've got that apart get your fingers in and pull them apart...dont be too forceful though...they mite need a bit longer in oven Quote Link to comment Share on other sites More sharing options...
snake Posted February 18, 2009 Share Posted February 18, 2009 if you are being cautious it will cool-down and will need re heating .just keep it away from the sides of the oven and keep an eye on it as homer said. when you do the second light you will be so much quicker;) Quote Link to comment Share on other sites More sharing options...
magictorch Posted February 19, 2009 Share Posted February 19, 2009 Thanks for the advice everyone, will try again after the weekend. Got the exhaust on J, sounds great i'm really happy with it:d:d Might see you on sunday, if i haven't broke my headlights by them:( Paul Glad your happy with it:) Fingers crossed for the weather:d Quote Link to comment Share on other sites More sharing options...
