Adam Kindness Posted September 17, 2002 Share Posted September 17, 2002 All seemed fine..... got away from the garage, gave it a boot full, no 2nd turbo just caries on with the acceleration from the 1st Any ideas.....??? Its going back in tomorrow for a service, so i'll get them to investigate...... thought they would have noticed this on the testdrive tho The exhaust blades and shaft were missing on No1 That was my problem I'll get pics of them tomorrow Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 17, 2002 Author Share Posted September 17, 2002 another thing... The Idle is really slow too Quote Link to comment Share on other sites More sharing options...
Alex Posted September 17, 2002 Share Posted September 17, 2002 If you've got hybrids now then you HAVE to have a pair! Can you confirm this?? Sounds like your vac hoses have been wired up incorrectly You idle should be around 6-800 rpm whilst warm. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 17, 2002 Author Share Posted September 17, 2002 no - i got Justin Foden's old set to use as a stop gap..... There std! It idles just above 500 and isnt the smoothest Quote Link to comment Share on other sites More sharing options...
Alex Posted September 17, 2002 Share Posted September 17, 2002 Can yo photo the engine bay? The turbo area...so that we can look at the connections etc. The idle does sound low...was anything done to the intake side of things? Have you hard reset your ECU?? Pull both EFI fuses to do this. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 17, 2002 Author Share Posted September 17, 2002 its going in to get fluids etc changed tomorow anyway..... so i'll get them to have a look..... see if theres any stupid mistakes going on The battery was disconnected, same effect as removing fuses Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 17, 2002 Share Posted September 17, 2002 Hmm. Normally when the sequential plumbing goes wrong you get behaviour like no boost or falling boost, rather than just one turbo working all in all. Can you give a detailed description of how the car performs? E.g. Do you still get a transition moment? What boost do you ge across the rev range? Is there a dropoff, even slight? Any different noises? Does the car feel like it loses or gains power at any point? What does the engine rev like from idle? Is there any coloured exhaust smoke - blue, black, white? If you rev the engine up and abruptly let off, does it return smoothly to idle of stutter, drop to very low rpm, stutter, nearly stall, that sort of thing? Any other wierdness, especially intermittent behaviour? Idle speed should be about 680rpm when warm, with no lights, rear demister, or aircon on. It should also be smooth with slight hunting variances now and again. -Ian Quote Link to comment Share on other sites More sharing options...
Nic Posted September 18, 2002 Share Posted September 18, 2002 How far have you run the car? If your battery has been disconnected then it will take a few miles for the ECU to re-learn the correct idle settings. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 18, 2002 Author Share Posted September 18, 2002 its back in the garage already, told them about the probs.... i'll c if they can fix it... they were meant to in the first place!! Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 18, 2002 Author Share Posted September 18, 2002 cars still in the garage they cant work out whats wrong They were trying to tell me thats how it should be!!! I.e turbos both working at the same time..... My response... er, NO! Justin, Chris - is it OK to give them your num so they can have a chat with someone whos knows the cars a bit better? Quote Link to comment Share on other sites More sharing options...
Branners Posted September 18, 2002 Share Posted September 18, 2002 Would it not be possible that the transition VSV which opens up the manifold to the second turbo isnt working? So all the boost just runs out turbo 1? If you get a slight drop at about 3500rpm then it could be the prespool bit is working but the main bit of transition over to turbo2 isnt working. You really need to watch the boost gauge as it does it. JB Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 18, 2002 Author Share Posted September 18, 2002 thats what i suggested to the owner of the garage... just feels as if the 2nd turbo isnt opening up (i'll get him to take it out tomorrow morning with me in the psgr seat watching the boost) me and him were pottering round for 30mins this eve, but he kept trying to tell me that supra turbos worked in parallel i just wish it was all better Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted September 19, 2002 Share Posted September 19, 2002 Originally posted by Adam Kindness me and him were pottering round for 30mins this eve, but he kept trying to tell me that supra turbos worked in parallel i just wish it was all better Maybe time for a different garage at their expense ? Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 19, 2002 Author Share Posted September 19, 2002 they seem concerned enough not to piss me off quite yet.... But i cant see where or why they get Jap Specialist from They have Evo's, Scoobs, FTO etc etc in and out all the time...... but surely they've noticed the sequntial turbos on a supra before ??? http://www.logansgarage.co.uk is there site for you to have a poke at Quote Link to comment Share on other sites More sharing options...
tDR Posted September 19, 2002 Share Posted September 19, 2002 You left your car with a garage in Leith Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 19, 2002 Author Share Posted September 19, 2002 nothing wrong with leith you seen the amount of supra's that go round about there ! Anyway - the car..... the fixed it..... was a disconnected vacuum hose.... they then fucked it again its back to what it was like before the 'good' turbos were fitted.... i hope to god they havent blown the new ones ona testdrive! Quote Link to comment Share on other sites More sharing options...
tDR Posted September 19, 2002 Share Posted September 19, 2002 Shouldn't the garage be liable for the turbo(s) they fucked then? Have a nice holiday btw? Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 19, 2002 Author Share Posted September 19, 2002 Aye.... loads of wee tarts to keep me happy They were used turbos.... i dont know where i stand Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted September 19, 2002 Share Posted September 19, 2002 Their web site gives me the impression they're a bit out of their depth (I see no Supras, Skylines or NSXs, just a Previa, MX5 and FTO). I suggest you download the section from this site on how the sequential turbo system works and show it to them. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 19, 2002 Author Share Posted September 19, 2002 i gave them a link to Pete Betts rundown on the sequentials.... Plus i think they phonned Justin, TorqueIC about 6times this afternoon for some help!!! Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 20, 2002 Share Posted September 20, 2002 Find out which vacuum hose. I'm trying to get an idea of the symptoms people get when various hoses are disconnected, and yours were symptoms I haven't experienced yet. And no, I'm not going to yank every hose off mine one at a time to find out -Ian Quote Link to comment Share on other sites More sharing options...
