2 piston caliper
jerkyboy18
Noticed my front right disc getting very hot and steering wobbling so i know i need new discs but i took pads off to look at pistons one was stuck out and was hard to push in ,but eventually got it moving . i presume both are meant to come out at the same time when i push brake pedal. when i put a spacer to block one the other comes out fine ,when i remove spacer only one moves out do i still need to free up more or replace piston.:rolleyes:
