servicing my supra
_Shane_
hey all,
going servicing my supra next weekend. Question for ye to make sure I get the proper gear for it.
What oil should i get ?
What spark plugs should i get ?
Car is running 1.2bar on hybrids with BPU and is producing 397bhp
and 430 torque. I know this question is probably asked on an ongoing basis but i would rather your info on what parts to get
than going by the info of some idiot working in a motor factors lol
cheers
shane
thanks gaz ;)
TT/hybrids @ upto 1.3bar
NGK - BCPR7ES (3330) - gap 0.7mm
NGK - BKR7E (6097) - gap 0.7mm
NGK - BKR8E - gap to 0.7mm
NGK - BCPR8ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX - leave gap alone
NGK Iridium - BKR8EIX - leave gap alone
Denso Platinum - PK20R8 - gap 0.7mm
Denso Iridium - IK22 - leave gap alone
Denso Iridium - IK24 - leave gap alone
out of the above , does it matter which ones are picked ???
When was it last serviced and what was replaced?
Has the following been done in the last year or 6000 miles:
- engine oil
- oil filter
- air filter
- plugs
In the last 3 years:
- brake fluid
- coolant
- gearbox oil
- fuel filter
In the last 5 years
- clutch fluid
- diff oil
Personally I always use silklene ProS for the engine oil, toyota filter, NGK copper plugs for BPU. Used to use Dot 5.1 for brake and clutch, but after some recent posts from CW think I'll be changing to a high quality Dot4 in future. Coolant, run of the mill Halfords Glycol based. gearbox, depends on which one. Fuel filter stock. Diff, Silkolene 75
Since i owned the soup, i change the rad with a performance rad and flushed the system out and filled it back up with toyota red for life or what ever it is called.
When i fitted the new D2's the brake fluid was sorted.
Only fitted a new hks filter a few months back.
What i plan on doing next saturday is
- engine oil
- plugs
- oil filter
Is the fuel filter easy to change ? Will sort that out too while its been done.
I have the car now about 16 months and have put up about 8k miles on it since then.
Before i bought the car it was fully serviced and had a timing belt change also
I run
Denso IK22 Plugs
Motul 300V Chrono 10W40 or Silkolene Pro S oil
LSD oil Castrol SAF-XJ 75w-140 but I have a carbonetics LSD so oil is changed every service
Blue Print Air/Toyota OEM/TRD panel filter
Motul RBF600 Brake Fluid
Oil Filter is Micropose or Toyota OEM/TRD
BSP in Ireland have great prices on Motul oil
http://www.bsp-imports.com/
Edited by Jellybean (see edit history)
  • 2 months later...
question, im looking to give the car a service soon, have bought silko pro s, coilpack clips, need oil and air filter, question is about plugs and if i should bother changing them, the previous owner had hks iridium put in back in 2006, car has done about 25k+ on them, car feels fine, no missfires etc. ive read that they only suppose to last around 15k, shall i bother changing them, if so thinking of the ngk iridium as im not paying £100 for hks, what grade ngk tho? 6,7,8
