_Shane_ Posted February 15, 2009 Share Posted February 15, 2009 hey all, going servicing my supra next weekend. Question for ye to make sure I get the proper gear for it. What oil should i get ? What spark plugs should i get ? Car is running 1.2bar on hybrids with BPU and is producing 397bhp and 430 torque. I know this question is probably asked on an ongoing basis but i would rather your info on what parts to get than going by the info of some idiot working in a motor factors lol cheers shane Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 15, 2009 Share Posted February 15, 2009 Plugs: http://www.mkivsupra.net/vbb/showthread.php?t=41927 Oil: http://www.mkivsupra.net/vbb/showthread.php?t=174725 Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted February 15, 2009 Author Share Posted February 15, 2009 thanks gaz TT/hybrids @ upto 1.3bar NGK - BCPR7ES (3330) - gap 0.7mm NGK - BKR7E (6097) - gap 0.7mm NGK - BKR8E - gap to 0.7mm NGK - BCPR8ES (3330) - gap 0.7mm NGK Iridium - BKR7EIX - leave gap alone NGK Iridium - BKR8EIX - leave gap alone Denso Platinum - PK20R8 - gap 0.7mm Denso Iridium - IK22 - leave gap alone Denso Iridium - IK24 - leave gap alone out of the above , does it matter which ones are picked ??? Quote Link to comment Share on other sites More sharing options...
Homer Posted February 15, 2009 Share Posted February 15, 2009 When was it last serviced and what was replaced? Has the following been done in the last year or 6000 miles: - engine oil - oil filter - air filter - plugs In the last 3 years: - brake fluid - coolant - gearbox oil - fuel filter In the last 5 years - clutch fluid - diff oil Personally I always use silklene ProS for the engine oil, toyota filter, NGK copper plugs for BPU. Used to use Dot 5.1 for brake and clutch, but after some recent posts from CW think I'll be changing to a high quality Dot4 in future. Coolant, run of the mill Halfords Glycol based. gearbox, depends on which one. Fuel filter stock. Diff, Silkolene 75 Quote Link to comment Share on other sites More sharing options...
Homer Posted February 15, 2009 Share Posted February 15, 2009 out of the above , does it matter which ones are picked ??? The Iridium based plugs will last longer, but will cost a lot more; the coppers will last less time, but cost pennies. IME: NGK BCPR7ES: £14, last 5k miles IK22: £55, last 8k miles Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted February 15, 2009 Author Share Posted February 15, 2009 Since i owned the soup, i change the rad with a performance rad and flushed the system out and filled it back up with toyota red for life or what ever it is called. When i fitted the new D2's the brake fluid was sorted. Only fitted a new hks filter a few months back. What i plan on doing next saturday is - engine oil - plugs - oil filter Is the fuel filter easy to change ? Will sort that out too while its been done. I have the car now about 16 months and have put up about 8k miles on it since then. Before i bought the car it was fully serviced and had a timing belt change also Quote Link to comment Share on other sites More sharing options...
Jellybean Posted February 16, 2009 Share Posted February 16, 2009 (edited) I run Denso IK22 Plugs Motul 300V Chrono 10W40 or Silkolene Pro S oil LSD oil Castrol SAF-XJ 75w-140 but I have a carbonetics LSD so oil is changed every service Blue Print Air/Toyota OEM/TRD panel filter Motul RBF600 Brake Fluid Oil Filter is Micropose or Toyota OEM/TRD BSP in Ireland have great prices on Motul oil http://www.bsp-imports.com/ Edited February 16, 2009 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
hadyn Posted February 17, 2009 Share Posted February 17, 2009 The Iridium based plugs will last longer, but will cost a lot more; the coppers will last less time, but cost pennies. IME: NGK BCPR7ES: £14, last 5k miles IK22: £55, last 8k miles I thought iridiums lasted longer than that? Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 25, 2009 Share Posted April 25, 2009 question, im looking to give the car a service soon, have bought silko pro s, coilpack clips, need oil and air filter, question is about plugs and if i should bother changing them, the previous owner had hks iridium put in back in 2006, car has done about 25k+ on them, car feels fine, no missfires etc. ive read that they only suppose to last around 15k, shall i bother changing them, if so thinking of the ngk iridium as im not paying £100 for hks, what grade ngk tho? 6,7,8 Quote Link to comment Share on other sites More sharing options...
AndyT Posted April 25, 2009 Share Posted April 25, 2009 (edited) Used to use Dot 5.1 for brake and clutch, but after some recent posts from CW think I'll be changing to a high quality Dot4 in future. Missed this. What's wrong with 5.1? I've changed to 5.1. Edit. Cripes. CW Link More CW wisdom Edited April 25, 2009 by AndyT (see edit history) Quote Link to comment Share on other sites More sharing options...
