barneybrendan Posted February 15, 2009 Share Posted February 15, 2009 had to relocate the resevoir on my na.the pump is as if it hasnt got enough fluid going through it.Also the resevoir is building up pressure and frothing out the lid.just noticed the 2 air pipes off the volve on the pump,do both have to be connected.If so where to,one is already connected to the pipe on the head . any advice on this would be appreciated Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2009 Share Posted February 15, 2009 Photos of what you have done with the reservoir, and the reasoning behind the move will help here. The idle up valve will have no bearing on the overflowing. Quote Link to comment Share on other sites More sharing options...
heckler Posted February 15, 2009 Share Posted February 15, 2009 Also the resevoir is building up pressure and frothing out the lid. the pressure/frothing sounds like its not been bled fully Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted February 17, 2009 Author Share Posted February 17, 2009 the resevoir is mounted where the charcoal canister used to be.the reason its there is because i have no room to fit it else where. ive just noticed a small leak,i will sort that out now. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted February 23, 2009 Author Share Posted February 23, 2009 power steering is still frothing,and pump is making a right racket. cracked the banjo`s off on the rack,main feed from pump fluid peed out.return banjo fluid came out not under pressure. the car was started twice when pipes were off causing the system to empty.(thanks to my brother). i have changed the resevoir now,used a toyota avensis one,which is mounted off the radiator and is above the pump so flow isnt an issue with that. need to get this sorted so i can get the car to interpro ,and get to drive it again. any advice will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
sypher_44 Posted February 24, 2009 Share Posted February 24, 2009 bleed the system? sounds like air i pressing stuff around Quote Link to comment Share on other sites More sharing options...
