dandan Posted February 15, 2009 Share Posted February 15, 2009 Does anyone have a compressor housing for sale to suit a Precision/BL T67? Ideally I'm looking for an "H" cover which is 4" intake and 3" outlet but would probably settle for a regular 4" inlet and 2.5" outlet as per most people's on here. Anybody got anything at all? Cheers Dan Link to comment Share on other sites More sharing options...
dangerous brain Posted February 15, 2009 Share Posted February 15, 2009 I have a bl housing with a 90 degree outlet if that is any help. Link to comment Share on other sites More sharing options...
dandan Posted February 16, 2009 Author Share Posted February 16, 2009 It might be yes. Is it a 2.5" compressor outlet version? Anyone else got anything different? Link to comment Share on other sites More sharing options...
dangerous brain Posted February 16, 2009 Share Posted February 16, 2009 I think so its in my locker I can measure it up in a bit if you like. Link to comment Share on other sites More sharing options...
dandan Posted February 16, 2009 Author Share Posted February 16, 2009 Yes please - I'd have to chop the bend off anyway but it would give me an idea which one it actually is. Also, would you let me know what A/R it is - I think it should be 0.68 or 0.69 whereas the 3" outlet version is a 0.70 Link to comment Share on other sites More sharing options...
dangerous brain Posted February 16, 2009 Share Posted February 16, 2009 Sorry I didn't get back online chap. I will check it tomorrow when I am back at work. Link to comment Share on other sites More sharing options...
dandan Posted February 16, 2009 Author Share Posted February 16, 2009 Sorry I didn't get back online chap. I will check it tomorrow when I am back at work. No problem, thanks. Link to comment Share on other sites More sharing options...
dangerous brain Posted February 19, 2009 Share Posted February 19, 2009 Sorry about the delay. It has a sticker on it with precision 6776rs turbo on it. The housing has a/r .70 EC-1 m24 embossed in big numbers 25/n and 9/90 in little numbers. The inlet is 101 mm and outlet is 56 mm internally and 66 mm externally. The straight outlet that the 90 degree elbow is welded onto is slightly narrower maybe 53 mm externally. The 90 degree union points roughly 45 degrees forwards from the plane cut flat through the turbo looking directly into the compressor ie pointing across and back underneath the inlet pipe. Link to comment Share on other sites More sharing options...
dandan Posted February 21, 2009 Author Share Posted February 21, 2009 OK great, thanks....let me just make some enquiries about it fitting.... Link to comment Share on other sites More sharing options...
