T67 Compressor Housing
dandan
Does anyone have a compressor housing for sale to suit a Precision/BL T67?
Ideally I'm looking for an "H" cover which is 4" intake and 3" outlet but would probably settle for a regular 4" inlet and 2.5" outlet as per most people's on here.
Anybody got anything at all?
Cheers
Dan
Sorry about the delay. It has a sticker on it with precision 6776rs turbo on it. The housing has a/r .70 EC-1 m24 embossed in big numbers 25/n and 9/90 in little numbers. The inlet is 101 mm and outlet is 56 mm internally and 66 mm externally. The straight outlet that the 90 degree elbow is welded onto is slightly narrower maybe 53 mm externally. The 90 degree union points roughly 45 degrees forwards from the plane cut flat through the turbo looking directly into the compressor ie pointing across and back underneath the inlet pipe.
