supraszr Posted February 13, 2009 Share Posted February 13, 2009 I have a problem with my central locking, The car will lock but wont unlock. If you use the key on the drivers door its fine but only unlocks the drivers door and not both (This may be the case normally but as I had no problem till now I never tested the key in the door) I just need to know if any of you think it requires replacement parts? or just all the wiring checked? Does anyone know where the Central locking control module is? or where to get a replacement? Link to comment Share on other sites More sharing options...
supraszr Posted February 13, 2009 Author Share Posted February 13, 2009 Forgot to mention an important part this fault is intermitant but is not working more than working. Link to comment Share on other sites More sharing options...
Al Massey Posted February 13, 2009 Share Posted February 13, 2009 I used to get this, always intermittent I took of the door cards and checked all the wiring and connectors and dried them out as my car had been standing for a few months while i was away in Iraq. dont have a problem now Link to comment Share on other sites More sharing options...
supraszr Posted February 13, 2009 Author Share Posted February 13, 2009 I think you might be onto something here, that would make sense the car has been stood for 2 months as I have just had knee sergery. Which bits did you remove and how did you dry them out? Airing cuboard job? Link to comment Share on other sites More sharing options...
Al Massey Posted February 13, 2009 Share Posted February 13, 2009 No just unplugged everything and had a good look and used a cloth to wipe and dry the connectors Link to comment Share on other sites More sharing options...
supraszr Posted February 13, 2009 Author Share Posted February 13, 2009 Thanks mate will give it ago! Link to comment Share on other sites More sharing options...
supraszr Posted February 14, 2009 Author Share Posted February 14, 2009 Tried to dry it out but had no luck, dried all connection behind the drivers door card but no resloution. Really stuck on this one might have to book it in! Link to comment Share on other sites More sharing options...
AndyT Posted February 14, 2009 Share Posted February 14, 2009 Just a quick one bud. Is the central locking switch in the drivers door ok. Its happened before where its been stuck in the closed position. Probably not your problem because you've had everything out. Link to comment Share on other sites More sharing options...
Konrad Posted February 14, 2009 Share Posted February 14, 2009 There is white 3-cable connector in drivers door. Disconnect it and try central locking by remote. If it will lock/unlock, you need to clean this connector or change it. Link to comment Share on other sites More sharing options...
supraszr Posted February 16, 2009 Author Share Posted February 16, 2009 Just a quick one bud. Is the central locking switch in the drivers door ok. Its happened before where its been stuck in the closed position. Probably not your problem because you've had everything out. Hi, yeh its seems ok was messing around with it the other night locking and unlocking. Its weird I got it working by doing this then it stops again. Link to comment Share on other sites More sharing options...
supraszr Posted February 16, 2009 Author Share Posted February 16, 2009 There is white 3-cable connector in drivers door. Disconnect it and try central locking by remote. If it will lock/unlock, you need to clean this connector or change it. Cheers mate will check this out Link to comment Share on other sites More sharing options...
Aldo87 Posted February 16, 2009 Share Posted February 16, 2009 I had the same problem and one day it fixed itself. The cars now been sitting for a while and its started to act up again. Could you let me know how you get on with the white cable on the module Link to comment Share on other sites More sharing options...
supraszr Posted March 10, 2009 Author Share Posted March 10, 2009 I had the same problem and one day it fixed itself. The cars now been sitting for a while and its started to act up again. Could you let me know how you get on with the white cable on the module Its all resolved now but same as yours it fixed itself, it is deffo damp getting into it I supect the drivers door. Got another issue now trying to wire in Central locking to a Falcon Evo4. Link to comment Share on other sites More sharing options...
cheekymonkey Posted March 21, 2009 Share Posted March 21, 2009 Hey all - I have this same issue - it suddenely stopped working after my last visit to a garage (however they did nothing electrical). I've taken my driver's side door card off, and there's only one connector which goes to the bank of door switches. I disconnect this and the problem is still there. Doesn't look damp or anything either. To confirm my problem is that the remote alarm fob won't unlock to doors, but it will lock them OK. Also the central locking does the same thing - when I lock the driver's door the passenger lock too but then won't unlock. Link to comment Share on other sites More sharing options...
Kevan Posted August 14, 2009 Share Posted August 14, 2009 Sorry to ressurrect an old thread but I'm having similar problems with my central locking. It/'s never worked on the remote fob at all but that's possibly a battery issue. The key will unlock each door or the boot but won't centrally unlock. It will, however, centrally lock. I've recently had a Clifford alarm fitted and the fob will lock both doors and boot but won't unlock anything. The alarm fitter tested all the motors and they work fine, both locking and unlocking. He has suggested that the central locking control module is faulty. I seem to recall reading somewhere about resetting the central locking module but try as I might, I can't find it again and don't know what's involved. I suspect that may be down to a faulty memory (Old age ya know). Can anyone advise me where the module is located and whether it can be reset? TIA K. Link to comment Share on other sites More sharing options...
Kopite Posted November 14, 2009 Share Posted November 14, 2009 BUMP - i'm also having this problem too, car will lock by the fob (Clifford) but won't unlock the doors. Any suggestions? Don't think there's any damp getting in but will get the door card off tomomorrow Link to comment Share on other sites More sharing options...
mwilkinson Posted December 1, 2009 Share Posted December 1, 2009 My central locking has stopped working as of this morning. I think it's the frost and damp that has done it. The doors will lock but not unlock. That's both by the key fob and internal switch. I have put the car in the garage. Will see if a few days drying out solves this. If not will have a look at the wires behind the doorcard when I'm next off. Seems this is the first step. Next will be to prevent it from happening again. Link to comment Share on other sites More sharing options...
mwilkinson Posted December 1, 2009 Share Posted December 1, 2009 BUMP - i'm also having this problem too, car will lock by the fob (Clifford) but won't unlock the doors. Any suggestions? Don't think there's any damp getting in but will get the door card off tomomorrow I also have a Clifford alarm. Don't think that's a factor at the moment though. Did you get this resolved? Link to comment Share on other sites More sharing options...
Neil-NA Posted December 11, 2009 Share Posted December 11, 2009 Sorry to bring this back up YET again but has anyone managed to sort the central locking issue out? I have a clifford and can lock the doors but not unlock them with the fob, however if i use the key the door will unlock, i noticed that when i press the fob to unlock the doors that the door open light on the dash flashes on. Had a search and this seems very common, so what's the answer? Link to comment Share on other sites More sharing options...
ronttuk Posted December 11, 2009 Share Posted December 11, 2009 we got the opposite ours unlocks by remote but wont lock and using the keys or door locks has no impact at all maybee ill take it apart see what i can find Link to comment Share on other sites More sharing options...
Kopite Posted December 11, 2009 Share Posted December 11, 2009 Mine started working again on it's own Link to comment Share on other sites More sharing options...
Neil-NA Posted December 11, 2009 Share Posted December 11, 2009 I will try taking the door card off over the weekend to see if its got damp in there as i did have the car jet washed during the day, just cant see why it would lock but not unlock. Link to comment Share on other sites More sharing options...
Neil-NA Posted December 12, 2009 Share Posted December 12, 2009 Went to try the car this morning and the central locking just doesnt work now Its can only be the damp and cold surely. Link to comment Share on other sites More sharing options...
gordy07 Posted December 13, 2009 Share Posted December 13, 2009 Went to try the car this morning and the central locking just doesnt work now Its can only be the damp and cold surely. Me too:( Link to comment Share on other sites More sharing options...
mwilkinson Posted December 13, 2009 Share Posted December 13, 2009 I took my central locking ecu out the other day and found a deposit on the pcb. I gave it a clean and everything worked again. That was unitil I put the dash together again. Doh! I think it's the connection to the central locking control unit. Will be doing some testing with my trusty meter on Wednesday. Will make sure I fix it. Link to comment Share on other sites More sharing options...
