Dazzi Posted February 14, 2009 Share Posted February 14, 2009 I lost 100 miles to a tank when I fitted my new wheels. The garage blew them upto 28psi instead of 36. I could see the needle go down Quote Link to comment Share on other sites More sharing options...
suprasam77 Posted February 14, 2009 Share Posted February 14, 2009 I lost 100 miles to a tank when I fitted my new wheels. The garage blew them upto 28psi instead of 36. I could see the needle go down this is probably also because your speedo is out as you have much bigger wheels than standard. so your doing the same miles in real life but your speedo thinks your doing less! common problem with switching to bigger wheels. Quote Link to comment Share on other sites More sharing options...
CarlT67 Posted February 14, 2009 Share Posted February 14, 2009 this is probably also because your speedo is out as you have much bigger wheels than standard. so your doing the same miles in real life but your speedo thinks your doing less! common problem with switching to bigger wheels. If you change your wheels to larger, you should down size the profile of the tyre so that the rolling radius of the complete wheel is the same and therefore the speedo in not affected. Quote Link to comment Share on other sites More sharing options...
suprasam77 Posted February 14, 2009 Share Posted February 14, 2009 it depends what widths he was running before and after aswell. but yeah you really should check before you buy wheels. try get slightly smaller rolling radius as your speedo will say your going faster than you are, so less likely to get caught speeding! lol Quote Link to comment Share on other sites More sharing options...
Dazzi Posted February 14, 2009 Share Posted February 14, 2009 this is probably also because your speedo is out as you have much bigger wheels than standard. so your doing the same miles in real life but your speedo thinks your doing less! common problem with switching to bigger wheels. I didn't switch to bigger wheels. I went 1" smaller. After I blew them upto 36psi I now get my usual 340 miles to a tank. Quote Link to comment Share on other sites More sharing options...
R Black Posted February 14, 2009 Share Posted February 14, 2009 I drove through the centre of london once in jams to mitcham 3up & i think i was getting like 14 odd mpg, on another occasion (2 up & luggage) i drove to Blackpool & then back on a full tank, i did an extra £20 on leaving Blackpool, but i had lots left on my return, at a guess £15 to £20 worth, the mpg on that trip was probably double the other figure, so type of driving can have loads to do with mpg figures. Quote Link to comment Share on other sites More sharing options...
Lbm Posted February 14, 2009 Share Posted February 14, 2009 Only a few weeks ago I had the original O2 sensor replaced on my TT. One of the reasons being 18mpg under a conservative right foot, the other being it was 100,000 miles old- so to speak. The results of my new mpg? No idea- went to take her out yesterday...bloody battery's flat Quote Link to comment Share on other sites More sharing options...
Konrad Posted February 14, 2009 Share Posted February 14, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=152779 Quote Link to comment Share on other sites More sharing options...
dani_r Posted February 14, 2009 Author Share Posted February 14, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=152779 Nice one Quote Link to comment Share on other sites More sharing options...
Dazzi Posted February 14, 2009 Share Posted February 14, 2009 Nice one Don't think this is a cure, mine lasted 9 weeks with the lemon treatment before I suffered from bad mileage again. I bought 2 x 20 quid universals sensors in the end. Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 15, 2009 Share Posted February 15, 2009 Don't think this is a cure, mine lasted 9 weeks with the lemon treatment before I suffered from bad mileage again. I bought 2 x 20 quid universals sensors in the end. Not always as the sensor may be too far gone (like charging up a shagged battery) - but it is a good diagnostic test to see if it is the O2 sensors before forking out on new ones. -Ian Quote Link to comment Share on other sites More sharing options...
dani_r Posted February 15, 2009 Author Share Posted February 15, 2009 Don't think this is a cure, mine lasted 9 weeks with the lemon treatment before I suffered from bad mileage again. I bought 2 x 20 quid universals sensors in the end. Where did you get the universal ones from? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted February 15, 2009 Share Posted February 15, 2009 http://www.buypartsby.co.uk/lambda_sensors.php Unfortunately they don't sell the flanges anymore to allow the 02 sensor to be screwed in. There are a few companies on ebay that sell them. Make sure you buy the right one i.e 1 wire etc. They all do the same thing at the end of the day. Quote Link to comment Share on other sites More sharing options...
dani_r Posted February 16, 2009 Author Share Posted February 16, 2009 Ah good stuff. Did you buy the 2 wire sensor? Quote Link to comment Share on other sites More sharing options...
Konrad Posted February 16, 2009 Share Posted February 16, 2009 Check how many wires you have on yours and buy same type. Some have 1 wire some have 2. Quote Link to comment Share on other sites More sharing options...
