Part Numbers Required - Please see Photo!
DaveSupTT
Please can anyone provide me with the part numbers for the following parts shown below.
I called into Toyoto (before I had this photo) and described what I was after but they said that they can only provide me with a bran new complete component, which was something like £500! :blink:
Surely I can replace these parts im after without replacing everything.
It even says in the Manuals I have got from CJ to replace them, but they dont give the part numbers.
Thanks for your help!
Dave
They list the following:
22278-46010 Gasket (the flat metal one)
90210-25001 Washer seal (the rubber doughnut)
25748-88400 Valve check. (the valve/piston thing from inside the iacv)
They don't list the o ring as a seperate component.
They also list the valve assembly as 22278-46010, but they dont make it clear if you also need to buy the other 3 parts listed as well.
