Few bits!
steb9780
Got a few bits for sale here. Pictures are below. Not to sure if these prices sounds right, shout up if they ain't
-GReddy twin 60mm pillar pod (only in my car for about 6 weeks), had to trim the holes out a bit as my 60mm gauge didn't fit. Comes with fixing screws and screw cap covers. Obviously the gauges aren't included. £40 - SOLD
-Dash pocket (takes up one DIN sized space under/above the stereo) had some crudely cut holes in the back for leads for my SAFC, but you couldn't see them once the pocket is filled. £6
-Throttle control ECU, this has took a knock when I crashed the car (see the picture), there are no sounds of anything being loose inside, but obviously i can't guarantee it's working, one of the mounting brackets is ben too. £10
-Custom CNC made alloy HKS turbo timer holder. I made this myself at work from aircraft grade alloy. It held my HKS turbo timer to the panel near the drivers legs. I fitted it with some little strips of foam to stop any vibrations. It was made to fit this type of HKS turbo timer £20
http://mr2.com/OWNERS/GRAPHICS/gs_turbo_t.jpg
I have put a photo of my drivers layout on too, you can see the pillar pod and the turbo timer holder (just) in this picture.
  • 2 weeks later...
