So..I erm..I'm...I mean my friend is looking for an NA.
RedM
  • Replies 60
I'd have thought that weight at either end would create a pendulum effect. Odd.
In mid-slide the weight distribution of a mid-engined car will mean that the rear end swings out almost uncontrollably, which is what the learned sir meant by a pendulum effect. It's far from an accurate description, because the pendulum effect is actually amplified by a car being mid-engined, not created by it.
Basically, if you lose the back end on an MR2 you'll know about it. Reverse generally has to be engaged. In a Supra you've got less chance of looking like a mong :)
I stand corrected in my description! But you knew what i meant:p
When I looked about 6 months ago £3000 didnt get an e36 M3...
I remember seeing a 4 door M3 for nearer to £4000. And in my researching I read that the difference between a 328i and an M3 was huge, but if you had the M3 you needed to put at least £1000 away in the bank for when it went wrong.
