Rich Posted February 10, 2009 Share Posted February 10, 2009 Hi guys, I have just removed the stereo,moved the orange and grey boxes out of the way.Noticed these 2 metal boxes .The plug was not connected to the top box. I was wandering if anybody could tell me what this box is for? TIA:) Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 10, 2009 Share Posted February 10, 2009 Bottom one is ABS ecu iirc, and i think top is active spoiler ECU Quote Link to comment Share on other sites More sharing options...
jamesmark Posted February 10, 2009 Share Posted February 10, 2009 Top one is the Active spoiler ECU. Quote Link to comment Share on other sites More sharing options...
Rich Posted February 10, 2009 Author Share Posted February 10, 2009 Thanks Rob/James-thats why it has been unplugged then! Quote Link to comment Share on other sites More sharing options...
Homer Posted February 10, 2009 Share Posted February 10, 2009 Because you don't have an active front spoiler anymore Quote Link to comment Share on other sites More sharing options...
jamesmark Posted February 10, 2009 Share Posted February 10, 2009 For a laugh unplug the bottom and break from 150 in 5 seconds. How close are to finishing it? Last time I say it @ Andy's it still had half an engine. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted February 11, 2009 Share Posted February 11, 2009 Is this UK or J-spec? I have been looking for my trac ecu (j-spec) but can't really find it. Especially if it looks anything like this. Quote Link to comment Share on other sites More sharing options...
heckler Posted February 11, 2009 Share Posted February 11, 2009 Is this UK or J-spec? I have been looking for my trac ecu (j-spec) but can't really find it. Especially if it looks anything like this. Trac ECU sits next to the Engine ECU in the passengers footwell - same for UK and JSpec Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted February 11, 2009 Share Posted February 11, 2009 Trac ECU sits next to the Engine ECU in the passengers footwell - same for UK and JSpec I've looked and looked untill I got sick from laying with my head in the stupid position. I can see any harness, or plugs. Do I have to remove anything to get in there? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted February 11, 2009 Share Posted February 11, 2009 I've looked and looked untill I got sick from laying with my head in the stupid position. I can see any harness, or plugs. Do I have to remove anything to get in there? yes you need to pull the carpet back and remove the plastic foot rest to get to the ECU Two 10mm bolts at the bottom and thats it if I recall correctly. Is the car a manual or Auto? Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted February 11, 2009 Share Posted February 11, 2009 yes you need to pull the carpet back and remove the plastic foot rest to get to the ECU Two 10mm bolts at the bottom and thats it if I recall correctly. Is the car a manual or Auto? 6sp, whats the difference here?. So I would need also to remove lists along the door to get the carpet back, right? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted February 11, 2009 Share Posted February 11, 2009 Thats correct you will need to remove the plastic trim along the door and unclip the carpet Just that the TRAC is used as part of the auto system and removing it on an auto can make the gear change very lumpy. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted February 11, 2009 Share Posted February 11, 2009 Thanks mate... I would be happy to be free from pressing that trac button contantly. No worries with my ABS system, right? Only the tracktion control will be switched off? Quote Link to comment Share on other sites More sharing options...
SimonT Posted February 11, 2009 Share Posted February 11, 2009 (edited) Do you have to unplug this when you have a FMIC fitted or can you disconnect elsewhere?? Edited February 11, 2009 by SimonT spelling!! (see edit history) Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted February 11, 2009 Share Posted February 11, 2009 Thanks mate... I would be happy to be free from pressing that trac button contantly. No worries with my ABS system, right? Only the tracktion control will be switched off? No the ABS is a seperate control system, as I understand it Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted February 11, 2009 Share Posted February 11, 2009 Do you have to umplug this when you have a FMIC fitted or can you disconnect elsewhere?? If you refering to the Active spoiler control unit that the first pic is showing then yes you have to disconnect it. If you dont then you get the warning triangle on in the centre of the dash. Quote Link to comment Share on other sites More sharing options...
SimonT Posted February 11, 2009 Share Posted February 11, 2009 If you refering to the Active spoiler control unit that the first pic is showing then yes you have to disconnect it. If you dont then you get the warning triangle on in the centre of the dash. Yeah i am oops!! Thank you!! Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted February 11, 2009 Share Posted February 11, 2009 No probs, if your fitting a FMIC then you will have to take the whole lot off anyway, so eveything thats part of the assembly for the front bumber the ECU for it (the top one in the pic above) and the switch, that way you can sell it as a complete unit and it will be worth more Quote Link to comment Share on other sites More sharing options...
Rich Posted February 11, 2009 Author Share Posted February 11, 2009 For a laugh unplug the bottom and break from 150 in 5 seconds. How close are to finishing it? Last time I say it @ Andy's it still had half an engine. I have completed the build now Mark .I have a base map ,Just needs mapping up by Ryan! Quote Link to comment Share on other sites More sharing options...
SimonT Posted February 11, 2009 Share Posted February 11, 2009 No probs, if your fitting a FMIC then you will have to take the whole lot off anyway, so eveything thats part of the assembly for the front bumber the ECU for it (the top one in the pic above) and the switch, that way you can sell it as a complete unit and it will be worth more Is it worth removing completely do you think or is it better just to keep it constantly in the down position? Quote Link to comment Share on other sites More sharing options...
SimonT Posted February 12, 2009 Share Posted February 12, 2009 Anybody? Quote Link to comment Share on other sites More sharing options...
jamesmark Posted February 12, 2009 Share Posted February 12, 2009 Anybody? Simple answer is, do what you want it is your car. If you are looking for a personal opinion then I would keep it if remaining stock. If you plan to ruin your car (again my opinion) with a stupid bodykit, then do not fit it. If the car is only being used on the road or limited track use then I do not think there will be any performance/handling issues. Quote Link to comment Share on other sites More sharing options...
