terribleturner Posted March 29, 2005 Share Posted March 29, 2005 Just trying to "back up" a couple of dvd's and it gets to about 23-27% of the analyses and i get this message... "DVD Shrink encountered an error and cannot continue. Failed to read file Q:\ Data error (cyclic redundancy check)." Any ideas?? Quote Link to comment Share on other sites More sharing options...
jonshaw_uk Posted March 29, 2005 Share Posted March 29, 2005 use dvd decrypter to rip the dvd from the disc to the hard drive - it can remove enryption which may be the cuase of the errors u get, and also you change the region of the film using it. Then use dvd2one to shrink it back to 4.3gb and then use nero to burn it to DVD. slightly long winded but always works for me without any problems Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2005 Share Posted March 29, 2005 Q: drive. HAve you got a mapped drive? If you go to My Computer do you actually have a Q drive? Is this your DVD drive? If so, it maybe that it simply cannot read this disc? Does it do it to all discs? Can you rip the disc to the harddrive and convert from that? Try using Flask MPEG to pull the data off the disc first. Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2005 Share Posted March 29, 2005 Ah - or use dvd Decrypter like the man says! (easier than Flask) Quote Link to comment Share on other sites More sharing options...
SteveL Posted March 29, 2005 Share Posted March 29, 2005 I get this with some DVD's, it's basically the drive not being able to read a track off the DVD. I usually use something like DVD Decrypter to copy the entire DVD to harddisk, then shrink that. Don't quite know why DVD Decrypter can read the tracks and DVD Shrink can't! If you can't find a link to it on the web, I'll try and get details later tonight. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 29, 2005 Author Share Posted March 29, 2005 Cheers guys. Stupid me forgot to say the my drive Q is actually my cd drive. I've never this trouble before but will try all advised processes to see if it works. Thanks again. Quote Link to comment Share on other sites More sharing options...
bromy Posted March 29, 2005 Share Posted March 29, 2005 Just trying to "back up" a couple of dvd's and it gets to about 23-27% of the analyses and i get this message... "DVD Shrink encountered an error and cannot continue. Failed to read file Q:\ Data error (cyclic redundancy check)." Any ideas?? I only use shrink, and have only come across this once, it turned out to be a bad disc it could not read it, i opened the disc up normally on the player and at that exact point a shitload of pixels flew across the screen. nick Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 29, 2005 Author Share Posted March 29, 2005 Interesting. They we're both new dvd's. The Forgotten and Layer Cake. Will actually have to watch them on a dvd player now to see. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 29, 2005 Author Share Posted March 29, 2005 Just went with DVD Decrypter as suggested by SteveL and worked a treat. Highly recommended Quote Link to comment Share on other sites More sharing options...
oxygene Posted March 29, 2005 Share Posted March 29, 2005 I usually use DVD X Copy and it does it all in one. Never had a problem with it! Quote Link to comment Share on other sites More sharing options...
