ball joints
gavin.starr
hey folks
is there any way of replacing the balljoints on the wishbones or is it just a case of buying the job lot. my mate works for renault and said that they can be replaced without buying the whole wishbone.
just wanted to know if this is possible thats all
cheers
gavin
if your mate could do this he will have a lot of customers on here, i have never heard of it done
im pretty sure it was done on a transit van or even the renault master van i cant remember what it was on now. ill ask him and find out. even if he could do it for the supra i dont know where he would find replacement balljoints on there own as the only ones i have come across is as afull wish bone.
i had mine changed about 4 months ago. the car doesnt feel the same anymore, feels even worse.
Which arms have you changed ? if youve changed the lower arms on either the front or rear it'll need the camber and track re setting
If you want new ball joints on a mkiv then its new wishbones im afraid, followed by getting the geo done
Which arms have changed ? if youve changed the lower arms on either the front or rear it'll need the camber and track re setting
i think that may be the problem. my steerng wheel doesnt sit straight when i wanna go in a straight line either.can any garage carry out this work or is it a specialist job?
Was the steering wheel straight before ? if so then the tracking is definetly out.
You dont really need a specialist to do this although i used one as i'd changed everything.
I've had expiriences with it being a bit difficult to find a garage to do the geo setup on the supra due to tire size. And I'm stock width with 18" rims. But it shouldn't be a problem. Fairly quick and cheap to get done. 50-100£ I would guess. Thats the price in Denmark at least. But you need to check with them that they have the equipment to do it. Any decent tire fitment shop should do it though.
