Headlight: Which connector is the headlight?
Guest vr4much
Guest vr4much
I'm trying to install day time running lights because I need them for an out of province inspection here in canada,
Can someone tell me which connector is the headlights ?
There are three, Right middle left
Guest vr4much
Do you mean the main driving lamp or the side light? Main lamp is the middle one, the sidelight is the outer one (unless you have the facelift lights, in which case it's still the outer one, but is mounted in the indicator.
okay I figured that part out now I gotta find a parking lamp,
does any1 know which one it is ?
Is it the tiny long light that goes underneath the 3 healight connectors ? I have to find a ground wire on the parking lamp
Is it the green or black ? there might be something wrong with my volt meter.
BTW am I talking about the right parking lamp ?
The parking lamp (called the side light here) has the long thing plastic mounting you mention if it's pre-facelift. There are two wires connected to it, one of them will have a green/black wire which I think is the positive. Its been a while since I last looked at them!
Guest vr4much
k both of my green and black wires read grounded..
I don't get this...
Edited by vr4much (see edit history)
