vvti shocker leak
Guest pande
Hi guy
Got a 98 vvti thats got a near side front shocker leak. Its got the shockers with an oil feed so need some help to sort it.
Can i recon it?
Is there any seconds out there?
How do i top up the oil? temp solution
Any help welcome as ive only had the car for a short while and at the moment its in for a full repaint so need to sort the shocker problem before building it up.
Thanks
I wished I knew, they may well have to be filled and pressurised.
I've got a little corrosion on the pipes which I wouldn't mind replacing. The mot bloke gave me an advisory on the brake pipes but I think he's got them mixed up with the ones for the shocks as they're very close.
Some other Toyota cars (4-runner is one) use a similar suspension setup (but the shocks are connected diagonally x-reas), I need to have a read of their workshop manuals to see if I can get any helpful information.
Here's some info on the x-reas that I've just found, I haven't found anything at all worthwhile for the reas in my previous searches.
Bare in mind that the two systems aren't connected in exactly the same way.
X-REAS Fitted to Toyota 4 Runner
Oil is filled in the components and a check valve is built in the joint portion, for serviceability.
Oil bleeding and changing cannot be implemented for X-REAS. Parts exchanging operation due
to the oil leakage should be done all as a set (front shock absorber, rear shock absorber, center control absorber, and tube assembly
I'm going to have another read in the morning as it's late and I'm off to bed. :yawn:
Edited by merckx (see edit history)
The check valves avoid the loss of fluid enabling some components to be replaced.
But:
An individual component may be replaced only when the system is repaired for the first time, provided that there is no oil leakage.
The last time I had a look of the epc I could only find the part numbers for the complete assembly. :blink:
