supraspeed Posted February 7, 2009 Share Posted February 7, 2009 ok when i start my car up, even idling for around 30sec, it looks like its getting incredibly hot very very fast. the temp guage doesn't increase, even in normal driving (just above halfway) but the exhaust still continues to smoke/fumes for 5 minutes after just on startup then shut off after 30 secs. is this normal on a single turbo setup? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 7, 2009 Share Posted February 7, 2009 I think you need to explain a little more on where it is getting hot? The fumes you talk of is that black smoke, blue smoke or white smoke? After 5mins it calms down, what do you mean Quote Link to comment Share on other sites More sharing options...
supraspeed Posted February 7, 2009 Author Share Posted February 7, 2009 I think you need to explain a little more on where it is getting hot? The fumes you talk of is that black smoke, blue smoke or white smoke? After 5mins it calms down, what do you mean white smoke. from the end of the exhaust/backbox. when i start it up and leave for 30sec, then switch off engine. now the exhaust is still steaming and is very hot, bit of white smoke still emerging. when the engine has just started up there is a lot of white smoke exiting. when i have turned off the engine, 5 mins later the exhaust has cooled down. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 7, 2009 Share Posted February 7, 2009 Sounds normal, especially if you have not used the car much, just condensation burning off, the exhaust will omit steam because its hot even when switched off for a little while On cold start the car idles higher and will get warm quite quickly, no issue When does it go off the Paul he will check it all over Quote Link to comment Share on other sites More sharing options...
supraspeed Posted February 7, 2009 Author Share Posted February 7, 2009 as soon as i get the remaining parts for the 6 speed conversion, i'm gonna try and get it all sorted out in one expensive hit. shame whifbitz can't get the parts otherwise it would have been finished weeks ago. Quote Link to comment Share on other sites More sharing options...
