Pig Posted February 7, 2009 Share Posted February 7, 2009 2 Step? All fixed now though thanks to Dave. Link to comment Share on other sites More sharing options...
JamieP Posted February 7, 2009 Share Posted February 7, 2009 Dodgy engine mounts maybe? Link to comment Share on other sites More sharing options...
AlanM Posted February 7, 2009 Share Posted February 7, 2009 Does that run from that stud? Link to comment Share on other sites More sharing options...
Pig Posted February 7, 2009 Author Share Posted February 7, 2009 JamieP said: Dodgy engine mounts maybe? Good suggestion, when I blow this engine i will def. uprate them. AlanM said: Does that run from that stud? Dont know. Link to comment Share on other sites More sharing options...
JamieP Posted February 7, 2009 Share Posted February 7, 2009 Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 7, 2009 Share Posted February 7, 2009 Have you got a flexy joint in the down pipe? if not, maybe time to fit one;) Link to comment Share on other sites More sharing options...
Pig Posted February 7, 2009 Author Share Posted February 7, 2009 Tricky-Ricky said: Have you got a flexy joint in the down pipe? if not, maybe time to fit one;) I did have, not sure if i do any more as i put on tanabe. Link to comment Share on other sites More sharing options...
Homer Posted February 7, 2009 Share Posted February 7, 2009 Jon, one thing I've always noticed with your car on the strip is the exhuast is getting thown around all over the place, it was slamming up and down about 6 inchs when you were doing your burnouts at pod... you can also see it in some of your videos. I guess the exhaust isn't mounted correctly and is putting a lot of stress on that downpipe... check the manifold too!! Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 7, 2009 Share Posted February 7, 2009 I will next week!! Whoops sorry Jon is that ok? Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 7, 2009 Share Posted February 7, 2009 AlanM said: Does that run from that stud? Nope it goes right past it about 2 inches..LOL:p Link to comment Share on other sites More sharing options...
SteveR Posted February 7, 2009 Share Posted February 7, 2009 Is the downpipe/turbo supported at all? Link to comment Share on other sites More sharing options...
supradibbs Posted February 7, 2009 Share Posted February 7, 2009 I would uprate your mounts and look at maybe a flex joint Link to comment Share on other sites More sharing options...
Pig Posted February 7, 2009 Author Share Posted February 7, 2009 Homer said: Jon, one thing I've always noticed with your car on the strip is the exhuast is getting thown around all over the place, it was slamming up and down about 6 inchs when you were doing your burnouts at pod... you can also see it in some of your videos. I guess the exhaust isn't mounted correctly and is putting a lot of stress on that downpipe... check the manifold too!! Ahhh, i wish you had said, no one ever drives my car properly with me watching, so i dont get to see that sort of thing. Dont suppose you have an example of a vid? SUPRALOOPY said: I will next week!! Whoops sorry Jon is that ok? Mate, ofcourse its ok..... dont suppose you could make sure the exhaust is mounted properly would you. It should be, whifbitz fitted it. Maybe needs new rubbers. SteveR said: Is the downpipe/turbo supported at all? Dont think so TBH, i think it just sits on the manifold and the down pipe has no support until it reaches the mid pipe. Link to comment Share on other sites More sharing options...
Homer Posted February 7, 2009 Share Posted February 7, 2009 Pig said: Ahhh, i wish you had said, no one ever drives my car properly with me watching, so i dont get to see that sort of thing. Dont suppose you have an example of a vid? I thought I did Might have been at the evening do after pod, so we weren't exactly sober! The vid I remember was one from a drag day you did a while ago, when you were really thrashing it and using the 2step. Link to comment Share on other sites More sharing options...
Pig Posted February 7, 2009 Author Share Posted February 7, 2009 Homer said: I thought I did Might have been at the evening do after pod, so we weren't exactly sober! The vid I remember was one from a drag day you did a while ago, when you were really thrashing it and using the 2step. I was stone cold sober Ahh, i think i know where to look, thx Edit: Thrashing it....... me ??? you sure Link to comment Share on other sites More sharing options...
SteveR Posted February 7, 2009 Share Posted February 7, 2009 Pig said: Dont think so TBH, i think it just sits on the manifold and the down pipe has no support until it reaches the mid pipe. I doubt that helps. Bignum made me a bit of support braket and welded that on to a stock support somewhere or other, part way down the downpipe. There is a lot of weight on the manifold otherwise, especially when you chuck the car around. Link to comment Share on other sites More sharing options...
Rich Posted February 7, 2009 Share Posted February 7, 2009 Looks like there has been some serious flex in the exhaust system coupled up with high temps.What D/P is it? As said above a flexy joint may help. Its usually the manifold which lets go on the welds . I dont reckon 2 step could cause this amount of damage. Link to comment Share on other sites More sharing options...
Pig Posted February 8, 2009 Author Share Posted February 8, 2009 Homer, I cant find the vid i was thinking of. Dont suppose you know wherre to look do you? Steve, good shout, i will speak to dave and see if he can make something up. Last thing i want is the manifold going as its all boostlogic stuff. Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2009 Share Posted February 8, 2009 Support it from the gearbox mate as that moves with the engine, thats how mine is done. Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 8, 2009 Share Posted February 8, 2009 JamieP said: Support it from the gearbox mate as that moves with the engine, thats how mine is done. Thats how they are originally fixed IIRC so if thats missing I'll make a new one;) Link to comment Share on other sites More sharing options...
Tom Posted February 8, 2009 Share Posted February 8, 2009 Pig said: Homer, I cant find the vid i was thinking of. Dont suppose you know wherre to look do you? I might have a clip from pod 08, I'll have a look for you today Link to comment Share on other sites More sharing options...
marbleapple Posted February 8, 2009 Share Posted February 8, 2009 Nice to see Dave is working hard! Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted February 8, 2009 Share Posted February 8, 2009 Ric your bits are done and I'll post out as soon as I get a min. Link to comment Share on other sites More sharing options...
paul mac Posted February 8, 2009 Share Posted February 8, 2009 i'm sure there are people here thinking what the hell is 2 step, are we talking anti lag Link to comment Share on other sites More sharing options...
adnanshah247 Posted February 8, 2009 Share Posted February 8, 2009 i was looking at that picture for like 15 mins and didnt notice anything until my 13 year old cousin brother just spotted out that theres a crack. im seriously not with it. Link to comment Share on other sites More sharing options...
