SUPRALOOPY Posted March 28, 2005 Share Posted March 28, 2005 i have just got my new toy and was wondering if any lights should come on the right hand side before you turn the key into the cranking position? after much squinting and reading the owners manual i can see that i have a check engine light,oil light and i think an oil temp light. should these lite up when the ignition is on but car is not running???? Quote Link to comment Share on other sites More sharing options...
Jake Posted March 28, 2005 Share Posted March 28, 2005 Yes they should. Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 bugger best i check the bulbs or the connections! if it is none of those then what do i do? car seems be to fine but if it isn't it can't tell me ooooopppps. any ideas? Quote Link to comment Share on other sites More sharing options...
Jake Posted March 28, 2005 Share Posted March 28, 2005 I'm pretty sure that the red triangle warning symbol on the rev counter also comes on when one of those lights on the RHS is illuminated. So if your red triangle light is working OK I guess you can assume the other lights aren't trying to warn you about something. Does the red triangle light up when the handbrake is on? Quote Link to comment Share on other sites More sharing options...
imi Posted March 28, 2005 Share Posted March 28, 2005 And ABS light should also come on if you have ABS Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 no should i be getting worried? the car does have a full service history and as far as know has well looked after. is there something that is done during certain mods that buggers these lights and therefore disconnected or should i start reaching for my wallet??(credit card to be honest) :-) Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 no abs Quote Link to comment Share on other sites More sharing options...
imi Posted March 28, 2005 Share Posted March 28, 2005 Whats the diff between Oil light and Oil temp light???? Is one Pressure while the second TEMP BTW: what lights do you have on the left side of the dash.....? Quote Link to comment Share on other sites More sharing options...
Jake Posted March 28, 2005 Share Posted March 28, 2005 Whats the diff between oil light and oil pressure light???? BTW: what lights do you have on the left side of the dash.....? One's oil level, one's oil pressure Seat Belt, bulb blown warning, Slip Control Off (Facelift only IIRC) errrr . . . some thing else I forget Quote Link to comment Share on other sites More sharing options...
Jake Posted March 28, 2005 Share Posted March 28, 2005 Whats the diff between Oil light and Oil temp light???? Is one Pressure while the second TEMP Temp? I don't think so mate, it's low oil level warning, innit? Quote Link to comment Share on other sites More sharing options...
hadyn Posted March 28, 2005 Share Posted March 28, 2005 my lights on the right cluster dont work - this is due to a dodgy dry solder joints on the loom that plugs into the lights. It's a common problem on mkiv's. Your warning triangle should work though, as not many people report problems with these... And as said above, does the warning triangle definately come on everytime a warning light in the right hand side is illuminated? Quote Link to comment Share on other sites More sharing options...
wkdtime Posted March 28, 2005 Share Posted March 28, 2005 dont worry mate, if you strip of the pannel in Q, i had the same issue, its the connections they need to be re soldered the bulbs are most likely fine, once you have whipped of the pannel play around with the connection and try again they should light up or atleast flicker! then re solder the bugger again! Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 sorry right hand side, low oil level,low oil pressure,malfunction ind. left hand side,battery,open door,what looks like a cat warning light,seatbelt light. this is all getting confusing cos i'm looking at my owners manual and its a 1994 and mine is 93 and the light set seems to be different. Quote Link to comment Share on other sites More sharing options...
imi Posted March 28, 2005 Share Posted March 28, 2005 Left hand side BATTERY..... Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 yep Quote Link to comment Share on other sites More sharing options...
Jake Posted March 28, 2005 Share Posted March 28, 2005 i'm looking at my owners manual and its a 1994 and mine is 93 and the light set seems to be different. I don't think there's any difference between J-spec '93 and '94 instrument warning lights. Is your owner's manual for UK spec Supras? Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 it says on the book printed in japan and has referances to left and right hand drive cars.??? Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 sorry to be a pain in the arse and not really know what i'm on about but i am now learnig about a whole different pedigree of car and to make things worse i am a machanic, but i only deal with classic rolls royce and bentleys. these cars are out of my league and i do need some help, also i do not want ruin my best toy ever !! Quote Link to comment Share on other sites More sharing options...
imi Posted March 28, 2005 Share Posted March 28, 2005 Would be nice to see a pic of ALL The lights that should come on during the ignition sequence. I have searched the manual and strange enough is DOES NOT say. Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 28, 2005 Share Posted March 28, 2005 I recently had all the lights in my Rh panel go out. Looks like it was the dry joint thing as when I pulled the dash off and wiggled the plug they all came back again. Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 what about this triangle light in the rev counter can anyone shed some light on wether it comes on when the handbrake is pulled or not??i am starting to think my car is not as it should be and my bum is starting to go :-( Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 28, 2005 Author Share Posted March 28, 2005 sod this i'm going to bed and will think about it in the morning,thats if i get any sleep thinking about possible solutions for the problem, thanks for all your help and if anyone does come up a quick fix i'll owe you a big fat pint!!!!!!!! Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 28, 2005 Share Posted March 28, 2005 what about this triangle light in the rev counter can anyone shed some light on wether it comes on when the handbrake is pulled or not??i am starting to think my car is not as it should be and my bum is starting to go :-( Yes it does. In fact it comes on whenever any of the other warning lights come on. Quote Link to comment Share on other sites More sharing options...
imi Posted March 28, 2005 Share Posted March 28, 2005 Yes it does. In fact it comes on whenever any of the other warning lights come on. Thats an easy one Quote Link to comment Share on other sites More sharing options...
Jake Posted March 28, 2005 Share Posted March 28, 2005 what about this triangle light in the rev counter can anyone shed some light on wether it comes on when the handbrake is pulled or not?( Sorry, it seems I didn't make myself clear. When I said to you "Does the red triangle light up when the handbrake is on?" I meant that it's a way to tell if your (You, Geeza) triangle light is working or not. I wasn't asking it as a question like "Is it supposed to come on?" Apologies for confusing you. Quote Link to comment Share on other sites More sharing options...
