removing handbrake handle
Guest cashie2000
  • 1 year later...
I did this a long time ago, i wanted to do it slowley but surely, i removed my driver seat, centre console + lid, pulled the carpet back near the handbrake, handbrake of on flat ground, theres a clip over the cable you need to pull up or out (which bends back later) dont remember how to get the cable of, but it a 17 year old dummy could do it im sure you can, after the the cable is of, 2 big bolts to remove the unit, then reverse this step to fit it:)
Kev
EDIT, if its just the grip, most aftermarkets slip over the stock one with some washing up liquid
