markylee Posted February 4, 2009 Share Posted February 4, 2009 help please, i own a 93 supra tt ive had it for three years, it has a very stiff suspension setup, and noticed lately when driving on the motorway lately that the rear end seems to rock from side to side , any answers??? Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted February 4, 2009 Share Posted February 4, 2009 Rear Upper Wishbone Bushes are quite commont to go on them, changed mine, and what a difference it made Quote Link to comment Share on other sites More sharing options...
michael Posted February 4, 2009 Share Posted February 4, 2009 Subframe bolts tight? Quote Link to comment Share on other sites More sharing options...
JamesF Posted February 4, 2009 Share Posted February 4, 2009 Read this title and thought it was about me! Quote Link to comment Share on other sites More sharing options...
markylee Posted February 4, 2009 Author Share Posted February 4, 2009 thanks guys, it was my first post ,didnt expect such a quick reply, good ere init lol Quote Link to comment Share on other sites More sharing options...
ellis Posted February 4, 2009 Share Posted February 4, 2009 Have you got that new 'Talk Steering' we're hearing so much about?!! Quote Link to comment Share on other sites More sharing options...
Chrisbeast Posted February 4, 2009 Share Posted February 4, 2009 Read this title and thought it was about me! Oooh er Does it happen more over bumpy roads, maybe you need the suspension geometry checked out? Mine pulls left and right all over the place over bumps in the roads! Must get it sorted out. Quote Link to comment Share on other sites More sharing options...
GoliathJay Posted February 4, 2009 Share Posted February 4, 2009 Mine feels awful at the moment, no confidence in its handling. Feels like its going to step out if I pull across lanes too quickly. hope geo set up will fix this! Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 4, 2009 Share Posted February 4, 2009 If it's only when you apply/remove power then check your tyre pressures. Quote Link to comment Share on other sites More sharing options...
markylee Posted February 5, 2009 Author Share Posted February 5, 2009 doesnt happen over bumps, mainly motorway , you can feel backend moving from side to side , but not all the time , only when the road is uneven , it seems fine round bends Quote Link to comment Share on other sites More sharing options...
Class One Posted February 5, 2009 Share Posted February 5, 2009 As others have said, first thing to check would be your tyre pressures. 34-36psi is the norm. After that if that hasn't eliminated your problem then probably worn bushes as Michael said. Quote Link to comment Share on other sites More sharing options...
Ian W Posted February 5, 2009 Share Posted February 5, 2009 Not to scare you but my supra suffered the same thing. As with any problem start at the cheapest or most likely solution and work forwards...I spent hundreds if not thousands and never found what it was. Quote Link to comment Share on other sites More sharing options...
