Heater only blows warm
rolli
Has anybody had the same problem?
Hows the best way to bleed the system?. I have flushed the heater out and theres a good flow and the engine temp seams ok.
Perhaps try a new temp switch for it? As the part that you are operating when turning the control dial to select your temperature. Get one off of a trader for very little
yep maybe the heater control dial. Not sure but it might be controlled by a variable resistor. Maybe the resistor is broken ?
